redneck_rams 360 build thread
Old Mar 2, 2013 | 05:35 PM
  #231
crazzywolfie's Avatar
crazzywolfie
they may look the same but i think in 99 the plug on the injector changed
99 and older injector plug
this is the one that should be on your truck
Old Mar 2, 2013 | 05:46 PM
  #232
redneck_ram's Avatar
redneck_ram
damn youre right. guess i can just get adapter harnesses.
Old Mar 2, 2013 | 05:59 PM
  #233
crazzywolfie
at least this is getting caught before you installed it. this could cause you to be without a truck for a couple days.
Old Mar 2, 2013 | 06:05 PM
  #234
gdstock's Avatar
gdstock
Been too busy to check in for a couple days. Looks good!
Old Mar 2, 2013 | 06:15 PM
  #235
redneck_ram
this is true. gonna try to get adapter harnesses, hopefully i can find some.
Old Mar 2, 2013 | 06:34 PM
  #236
redneck_ram
found these
http://www.summitracing.com/parts/cei-109076/overview/
http://www.summitracing.com/parts/tfs-89201/overview/
http://www.summitracing.com/parts/fm...j/media/images
gonna try to find more, but any one of those should work.
Old Mar 2, 2013 | 06:42 PM
  #237
gdstock's Avatar
gdstock
What about using the injectors that you are running in your truck?
Old Mar 2, 2013 | 06:44 PM
  #238
redneck_ram
dont know if they flow enough for a 5.9, i have a 5.2 currently.
Old Mar 2, 2013 | 07:43 PM
  #239
merc225hp's Avatar
merc225hp
That answer is over in the Diy area or
From the Q&A section of the April 2001 Mopar
Performance News:
Engine Years Flow rate in lb/hr
Neon ( All) 23.9
2.5 Magnum 91-95 17.4
2.5 Magnum 96-01 23.2
4.0 Jeep 91-95 21.4 (Equivalent to Lucas 5207013 )
4.0 Jeep 96-01 23.2 (Equivalent to Lucas 5208005 )
5.2 Magnum 92-95 18.2
5.2 Magnum 96-01 23.2
5.9 Magnum 93-95 24.5
5.9 Magnum 96-01 23.2 (Seimens/Chrysler P/N 53030778)
Old Mar 2, 2013 | 07:50 PM
  #240
redneck_ram
Performance News:
Neon ( All) 23.9
you, sir, are the man! guess i could just switch out the injectors from my 5.2, or buy zmans injectors. he lives only 30~ minutes from me. could also just get adapters, and be done with it.
these are the injectors zman has... https://dodgeforum.com/forum/parts-s...injectors.html
