redneck_rams 360 build thread
Old Mar 20, 2013 | 05:11 PM
  #361
redneck_ram's Avatar
redneck_ram
cooling system is in, along with the transmission lines. didnt quite get the t-case in today.
learned that i need a tune ASAP! widebands showing wicked lean conditions at higher rpms when being revved. she sounds wicked good though!
Old Mar 20, 2013 | 05:26 PM
  #362
zman17's Avatar
zman17
Retired Moderator - RIP
You need to get it all together man. (as Merc stated). And you ran that motor with the tranny hooked up with no tranny line(s) ? I don't think that was a good plan. As in dry Torque Converter and trans ?
Old Mar 20, 2013 | 05:39 PM
  #363
redneck_ram
unfortunately so... ill get fluid in it and make sure its ok. shouldnt have hurt anything. wasnt run long... maybe a minute or two??
Old Mar 20, 2013 | 05:44 PM
  #364
zman17's Avatar
zman17
Those videos were longer than a minute or two. I know you can't wait, but calm down before something else gets screwed up. And IIRC, my scanner will also do idle. But , it needs to be all together.
Old Mar 20, 2013 | 06:06 PM
  #365
Jacksoncove's Avatar
Jacksoncove
Nice job Red!
Old Mar 20, 2013 | 06:32 PM
  #366
redneck_ram
ran it some more today(with fluid in it) and the idle is back to normal now. guess it just needed to run for a bit. need to hook up the o2 sensors. post cat cant be hooked up until i either lengthen the wires 2~ ft, or get an extension from summit(28 bucks)
Originally Posted by Jacksoncove
Nice job Red!
thanks bud!
Old Mar 21, 2013 | 04:42 PM
  #367
zman17's Avatar
zman17
Soldering iron, some wire, shrink wrap, die electric grease and some liquid tape will take care of making the o2 wire longer. I have all the above except you'll need wire. Actually, I might have enough wire too.
Old Mar 21, 2013 | 05:18 PM
  #368
redneck_ram
lengthen the o2 sensor side of the wire, and not the truck harness wire, corect?
Old Mar 21, 2013 | 06:14 PM
  #369
zman17's Avatar
zman17
Yes, just the o2 wires.
Old Mar 21, 2013 | 08:20 PM
  #370
woods4life's Avatar
woods4life
http://www.summitracing.com/parts/avm-30-5130
Hows this one look? Was thinking about ordering it tonight, just wanted your guys opinion
