redneck_rams 360 build thread
Old Jan 25, 2013 | 02:57 PM
  #31
redneck_ram's Avatar
redneck_ram
well, looks like we're not going to be getting a camper now. budget isnt there this year. however im still building the motor. i may even pick up a JY low mileage 360, and cam/build it instead!
Old Jan 25, 2013 | 03:41 PM
  #32
stewie01's Avatar
stewie01
4BT swap!
Old Jan 25, 2013 | 03:43 PM
  #33
redneck_ram
Originally Posted by stewie01
4BT swap!
i dont have that kinda money, nor the equipment to do that kinda swap.
Old Jan 25, 2013 | 03:44 PM
  #34
stewie01's Avatar
stewie01
Awe, that sucks But a nicely built 360 outta be plenty
Old Jan 25, 2013 | 05:51 PM
  #35
redneck_ram
found a 360 with about 130k on it from the same JY that zman visits on a weekly basis for 275. gonna go pick it up as soon as i get my returns. im gonna email hemifever now, and give him all my specs so i can figure out what kinda power im gonna be putting down at the flywheel. ill get it dyno tuned later on.
Old Jan 25, 2013 | 06:29 PM
  #36
stewie01's Avatar
stewie01
How it cranky doing?
Old Jan 25, 2013 | 06:44 PM
  #37
redneck_ram
dunno. havent talked to him for 2 weeks or so now. i imagine hes doing good, but hes supposed to be losing his house. dunno if it happened yet or not though.
Old Jan 26, 2013 | 01:19 PM
  #38
redneck_ram
well... with deciding on getting a used 360, merc talked me into building the short block as well. im either going with .030, or .040 over keith black 107 pistons. some sort of h-beam rods, stock crank. all clevite bearings. and im awaiting word from merc about a cam. going to be running 1.7's with this cam, an m1, a 50mm tb, and custom heads from odessa suited for my needs.
Old Jan 26, 2013 | 01:30 PM
  #39
merc225hp's Avatar
merc225hp
^^^ email sent
Link to one set of scat rod's
http://www.rpmmachine.com/shop/index..._detail&p=3095
Old Jan 26, 2013 | 02:49 PM
  #40
redneck_ram
ok, heres my parts list. it isnt everything, just the stuff im getting from summit.
stage 8 locking header bolts
http://www.summitracing.com/parts/stg-8915
comp double roller
http://www.summitracing.com/parts/cca-2103
clevite rod bearings
http://www.summitracing.com/parts/cle-cb481hn
mopar valve covers
http://www.summitracing.com/parts/dcc-5007617
arp head bolts
http://www.summitracing.com/parts/arp-144-3605
allstar o2 bung
http://www.summitracing.com/parts/aaf-all34153
clevite main bearings
http://www.summitracing.com/parts/cle-ms1266hg
hs 1.7's
http://www.summitracing.com/parts/csp-s70037
pacesetter long tubes
http://www.summitracing.com/parts/psm-70-2213
keith black 107 piston/ring kit .040 over
http://www.summitracing.com/parts/uem-kb107ktm-040
arp main studs
http://www.summitracing.com/parts/arp-140-5402
arp torque lube
http://www.summitracing.com/parts/arp-100-9910
comp cams, cam
http://www.summitracing.com/parts/cca-20-745-9
pacesetter lt y pipe
http://www.summitracing.com/parts/psm-82-1183
clevite cam bearings
http://www.summitracing.com/parts/cle-sh875s
magnaflow universal 3" cat
http://www.summitracing.com/parts/mpe-99009hm
thats everything from summit that ill need i believe. im also going to hughes for some h-beam rods, then obviously ill be getting lifters pushrods, and the m1 from the dealer. 50mm tb from 1999blkdakrt, heads from odessa, and a used 360 from a JY.
just trying to figure out if ill need a hardened oil pump shaft or not.
if anyone has any more ideas, or opinions, let me know.
