I think I would. 32k miles isn't that much, a top end rebuild should give some idea to what the bottom end looks likes, to a degree anyway. Right?
It's kind of a gamble either way, the '98 motor with more miles could be in better shape than the '94 with less, or the other way around.
true enough. i have a pretty much an unlimited income for this top end build. just couldnt swing a full on build right now.
i think im going to call hughes to see what kinda cams they suggest. i like the specs on the cam i linked to, but i want to get the most power possible outta this 360.
question... with bulding this top end( heads, cam, m1, lt's, custom exhaust) do i need to get bigger injectors, or will the stockers hold up?
Should be ok...... if you have problems with always running lean, then it's time to start looking at larger injectors. Wideband O2 may not be a bad plan.
wideband is already being ordered as recommended by hemifever. just wanted to make sure stock injectors would be ok, dont want any spark knock, or anything....
