Gutting my catalytic converter
I would not gut your cat..
cut it off and put a delete pipe in there, and sell your cat for recycling....do you know those cats are worth anywhere from $20 to $60 depending on what kind of vehicle they came off of?!
they contain precious metals like platinum in them that is worth a lot of money..
Well, here's the deal, If you gut the cat, the whole smog system will cease to work correctly. If you live in an area that doesn't require smog checks, then just delete the cat with a pipe that bolts in like the cat does and save the cat for when the POPO pulls you over for a loud vehicle and gives you a fixit ticket for it.
There are no smog tests where I live. I don't have the money for a new high flow cat. I would prefer just to remove the cat but if I gut it and leave it on then I'll still be able to pass inspection anywhere. I just hope the non fouler trick works for the CEL light.
Get a magnaflow high flow cat. I have that and the same muffler on my truck and I love the sound! Only diff is mine comes out in a single sidepipe
edit: just seen your last post. Remove the cat entirely, gutted cats just sound plain awful imo
i rana gutted cat for awhile, but have since smartened up and got a highflow(thanks zman)
just to the right thing, and listen to these guys, and get a highflow cat.
heck, in a couple weeks, ill have a magnaflow direct fit cat forsale. yeah its used, but still functions as it should.
where are you located?
