1996 Dodge Ram 1500 5.9 Water pump questions
Old 05-07-2013, 12:56 PM
Arde's Avatar
Arde
Arde is offline
Leave the serpentine belt on to hold the pulley, put a large wrench on the nut and whack it with a hammer. I had to use a 15" crescent, my 12" wouldn't quite fit.
The fan and fan clutch come off as one unit.
Old 05-07-2013, 01:16 PM
AaronFabian's Avatar
AaronFabian
AaronFabian is offline
okay i read on here that its a 36mm wrench is that true?
Old 05-07-2013, 01:31 PM
Arde's Avatar
Arde
Arde is offline
True, IIRC
Old 05-07-2013, 02:42 PM
AaronFabian
okay well im trying to find a wrench. i cant get a cresent wrench to fit in there.. :/
Old 05-07-2013, 06:34 PM
zman17's Avatar
zman17
zman17 is offline
Retired Moderator - RIP
Might as well rent a fan clutch removal kit from your local part store. You will at least get the money back. Don't buy a wrench, probably will be more than renting.
Old 05-07-2013, 09:21 PM
gdstock's Avatar
gdstock
gdstock is offline
Or get a bigger crescent wrench. Worked for me...
Old 05-07-2013, 10:53 PM
AaronFabian
i said screw it and took the whole water pump off and im gonna worry about the fan and stuff later. now im trying to figure out what i have to take off to get to the timing chain. pictures help im not used to working on trucks i have only 2 four cylinders lol
Old 05-08-2013, 02:01 PM
HeyYou is online now
Dodge Forum Administrator
Received 3,266 Likes on 3,013 Posts
Crank pulley/harmonic balancer, then, a selection of bolts, which you can see, and two more, coming up thru the oil pan. Should just pull right off then.
Old 05-08-2013, 05:13 PM
zman17's Avatar
zman17
zman17 is offline
Someone needs a Haynes manual.
Old 05-08-2013, 09:03 PM
AaronFabian
yeah i think i should get one
Quick Reply: 1996 Dodge Ram 1500 5.9 Water pump questions
