Power seats 98 1500
Old May 8, 2013 | 02:48 PM
Als70ss's Avatar
Als70ss
Talking Power seats 98 1500
Hi I have picked up a set of 40-20-40 front seat off of craigs list for my 98 ram and the seats came out of a 98. To my surprize they are power seats so here is my question. Where can I find a wiring harness or the part that plugs into the motors the driver has 3 motors and passenger has 2. I found a harness on ebay for 75 bucks and that is close to what i payed for the seats. looking for a cheaper option you know how it is when you don't have alot of cash to spend.
Old May 8, 2013 | 07:57 PM
How about the truck you got the seats from?
I don't think there are all that many wires. Grab the 01 service manual, see what wires you need, and maybe make your own harness?
Either that, or check your local junkyards.
Old May 8, 2013 | 09:05 PM
Spillage's Avatar
Spillage
The controls are on the seat, and the seat frame is a local ground, so it is likely to only need a power supply... this could be an unused connector under the carpet somewhere.
If I remember, I'll look at mine tomorrow and let you know where the seat plugs in.
Old May 9, 2013 | 12:27 PM
Als70ss's Avatar
Als70ss
I was told the seats came out from a 98. The plastic covers are without the switch opening I have the knowledge to make up my own harness but I don't have the proper connectors That plug into the motor. Will a harness from a 95 work?
Thanks
Al
Old May 9, 2013 | 12:41 PM
dodge dude94's Avatar
dodge dude94
Banned Goober Smoocher
If your seats don't have a switch opening then they aren't power seats. Unless I'm confuzzled.
Old May 12, 2013 | 01:45 PM
Spillage's Avatar
Spillage
The switches are in the seat side, and there is a flap below seat line to cover the seat frame.
There are only two wires going to a connector on the floor under the seat (where the floor pan steps up)... power and ground (?)
Old May 14, 2013 | 02:37 PM
Als70ss's Avatar
Als70ss
The motors are there on the Seat I got but there is no wiring or harness and the trim pieces I got did not have the switch assembly
Old May 14, 2013 | 07:21 PM
Spillage's Avatar
Spillage
LMC might have the switch cluster.
