Dana 60 Swap!
Old Sep 28, 2013 | 06:48 PM
  #71
merc225hp's Avatar
merc225hp
Lot's of work going on here, nice. Keep at it!
Old Sep 29, 2013 | 12:28 AM
  #72
Wh1t3NuKle's Avatar
Wh1t3NuKle
Nice work. I feel your pain with weight of that axle. At least the rear you're able to lift one a side at a time solo as opposed to the front.
Originally Posted by Ham Bone
Got the sob out
Leafs springs are a little heavy
Old Sep 29, 2013 | 10:06 AM
  #73
Ham Bone's Avatar
Ham Bone
Now I just have to finish cutting the front hangars out and I'm done pulling apart the parts truck
Old Oct 17, 2013 | 12:21 PM
  #74
Ham Bone's Avatar
Ham Bone
should have my ball joint press and 43mm socket to get the axle nut off this weekend, so hopefully there will soon be pictures of a pair of por-15 painted 60s
and likely some pics of destroyed wheel hubs also
should i use the 1500 control arms or the 2500 arms? Its been recommended to try the 1500s because the 2500 ones are shorter and put the axle too far back but what is everyone elses opinion
Old Oct 17, 2013 | 01:28 PM
  #75
dodge dude94's Avatar
dodge dude94
Banned Goober Smoocher
Why would the 2500 control arms be too short? I mean it's the same suspension geometry.
The best scenario is to get you some kickass adjustable control arms like White has.
Old Oct 17, 2013 | 01:40 PM
  #76
Ham Bone's Avatar
Ham Bone
i heard they were shorter becasue the 60 housing is so much bigger. ill measure them when i go home
and i doont feel like dropping more money on control arms
Old Oct 17, 2013 | 01:43 PM
  #77
dodge dude94
Well, if the housing is much bigger, but the control arms shorter to compensate, think about it. Since the arms are shorter, that would mean the chassis mounts are in the same place. So, with that in mind, you would likely need the shorter arms.
Old Oct 17, 2013 | 01:49 PM
  #78
Ham Bone's Avatar
Ham Bone
but supposedly they are too short and move the axle to far back
Old Oct 17, 2013 | 01:50 PM
  #79
dodge dude94
Well, you know what you have do.....
GET TO IT!
Old Oct 17, 2013 | 01:54 PM
  #80
merc225hp's Avatar
merc225hp
You guys so sure about this info? remember the 2500's sit higher than the 1500's. The 2500 arms should be longer than the 1500 arms and thicker to boot.
Edit: You do have both sitting there get a tape out and measure them.
