snowboundrmk's 360 build
Old Jun 15, 2014 | 09:27 PM
  #191
snowboundrmk's Avatar
snowboundrmk
I got my rockers and put them on. I filled the engine with oil and primed it. I think my gauge said like 50-60psi. I didn't have time to pay attention because I had to stop since oil was leaking from between the oil filter adapter and block. I think I'm going to take it off and put some rtv on it. Is that the right thing to do? I googled it and it came up that this was a known issue with the magnums. I circled where I think it was leaking from.
Old Jun 15, 2014 | 10:33 PM
  #192
snowboundrmk
Well I googled it more and it looks like there is supposed to be a gasket in there . I do remember scrapping off a ton of stuff from that spot though. I though it was just oil sludge. I remember seeing that gasket in my gasket set but I thought it was for in between the throttle body and air cleaner. Haha
Old Jun 15, 2014 | 10:39 PM
  #193
1997JollyGreenGiant's Avatar
1997JollyGreenGiant
I made that mistake before too! I built an engine once, fired it up and oil was shooting out the side from where the oil filter sits. I thought the gasket was for my throttle body. Oops...
Old Jun 15, 2014 | 10:47 PM
  #194
snowboundrmk
Ya hopefully I didn't do anything else dumb haha. Oh and i forgot to post the picture that made me figure it out:
Old Jun 17, 2014 | 04:03 PM
  #195
snowboundrmk
Does this all look right for the distributor. Engine is at #1 cylinder tdc compression stroke. Slot in intermediate shaft points toward left front intake bolt. Rotor points at mark in cam sensor plate.
Old Jun 17, 2014 | 04:22 PM
  #196
Looks like things are lined up correct. According to theory, there is an alignment mark on the intake for the dist as well, but, looking at your pics, I sure don't see it......
Old Jun 17, 2014 | 07:11 PM
  #197
Blue Mopar01's Avatar
Blue Mopar01
I had marked my 360 block where the orignal dizzy sat and put in my 318's in the almost exact spot. I had nothing wrong there.
Old Jun 17, 2014 | 10:12 PM
  #198
redneck_ram's Avatar
redneck_ram
i had this same issue with mine. you need to get the dizzy shaft turned clockwise 1 tooth. or you will have major issues with fuel sync.
edit: nevermid, youre good... had to look over my info again. and verify, but yours is fine!
Old Jun 18, 2014 | 03:56 PM
  #199
snowboundrmk
I found a picture from before the motor was apart and I can see how the distributor was. When I put it like in the picture the rotor is a little bit off from the mark on the cam sensor plate. I think the comp cam is advanced a few degrees over stock so that might be why. So should i set it so the rotor is lined up with the mark like in my picture, or how it was stock and have the rotor off a little?
Old Jun 18, 2014 | 11:59 PM
  #200
redneck_ram
nope, youre good. rotor should be directly behind the mark on the cam sensor.not directly in the middle.
