snowboundrmk's 360 build
Old Jun 20, 2014 | 11:25 PM
  #201
snowboundrmk's Avatar
snowboundrmk
Started tearing it apart.
Old Jun 21, 2014 | 05:41 AM
  #202
Wildman4x4nut's Avatar
Wildman4x4nut
Veteran: Army
Looking darn good. I'll bet you will have your swap done before mine is done and I have a head start on you too.
Old Jun 21, 2014 | 08:22 AM
  #203
tincan57's Avatar
tincan57
So far for Snow, 10 months and 1 week. Every picture tells a story. The trucks down time just began. I watch each with interest. First fire looming! Great threads guys. K.
Edit, Excludes pre-work
Edit 2: In gas turbines, First Fire meant Full Speed No Load testing. I have to remember this is Snows build thread. So terms should be first start.
Great thread!
Old Jun 21, 2014 | 08:46 AM
  #204
tbugden's Avatar
tbugden
I also watch this with keen interest. I have a 318 to swap into my v6 Dakota. Even though this is a 360 it provides some useful information, at least good ideas.
Old Jun 21, 2014 | 10:48 PM
  #205
snowboundrmk
Did some more today. First thing I did was take off the fan. I couldn't keep the water pump from turning with a screwdriver so I drilled a couple holes in a strip of steel and bolted it to the pulley. The pitman arm then held it from turning so I could put all my effort in to just the fan nut. I'm going to cut the a/c compressor mount off of the accessory bracket since I don't have a/c anymore.
Old Jun 22, 2014 | 10:34 PM
  #206
snowboundrmk
Not much to see but I did a lot of little things. Close to pulling it.
Old Jun 23, 2014 | 10:13 AM
  #207
Are the two remaining bolts going to be enough to hold that in place?
Attached Thumbnails snowboundrmk's 360 build-9b16a072-1588-432f-b769-ce0489b5163b_zpstewjfm3x.jpg
Old Jun 23, 2014 | 12:17 PM
  #208
snowboundrmk
There's another bolt behind the idler pulley and there is that bracket on top that connects it to the intake.
Old Jun 23, 2014 | 01:24 PM
  #209
That should be more than adequate to the task.
Old Jun 25, 2014 | 11:09 PM
  #210
snowboundrmk
Success!
