snowboundrmk's 360 build
Old Feb 22, 2014 | 07:46 AM
  #81
snowboundrmk's Avatar
snowboundrmk
Do you have the mopar tensioner, or just the stock thrust one?
Old Feb 22, 2014 | 08:46 AM
  #82
Spillage's Avatar
Spillage
This is what I got;
Amazon.com: Cloyes C3028x Chrysler Sb V8: Automotive Amazon.com: Cloyes C3028x Chrysler Sb V8: Automotive
$39.22 at the time.
Old Feb 22, 2014 | 12:02 PM
  #83
snowboundrmk
That's what I was looking for. Saves me a few bucks too.
Old Feb 23, 2014 | 07:58 PM
  #84
snowboundrmk
So this is my list of parts I need to get. Let me know if you think I'm forgetting something or if something won't work or there is a better alternative(e.g., different spark plug). I already have a thermostat and gasket
Cam: http://www.summitracing.com/parts/cc...rder=Ascending
333-summit
Heads:
700?-eBay
Timing set: http://m.summitracing.com/parts/clo-c-3028x
52-summit
Chain tensioner:
40-
Lifters: http://www.ebay.com/itm/170907788153...84.m1423.l2649
126-eBay
Pushrods: http://www.ebay.com/itm/141090655728...84.m1423.l2649
44-eBay
Head bolts: http://www.oreillyauto.com/site/c/de...2258&ppt=C0332
33-Oreillys
Headers: http://www.ebay.com/itm/STAINLESS-RACING-MANIFOLD-HEADER-EXHAUST-DODGE-RAM-DURANGO-DAKOTA-5-2L-5-9L-V8-/190691294428?pt=Motors_Car_Truck_Parts_Accessories&hash=item2c66163cdc&vxp=mtr 139-eBay
Y pipe: http://www.jegs.com/i/JEGS-Performan...33#moreDetails
148-jegs
Muffler: http://www.summitracing.com/parts/ho...6hkr/overview/
72- summit
2.5 to 3" exhaust: http://www.summitracing.com/parts/sum-652253/overview/
11-summit
Turndown: http://www.summitracing.com/parts/wlk-41095/overview/
20-summit
Water pump: need to check if press on or bolt on pulley
40?
Water pump bolts: http://www.oreillyauto.com/site/c/de...6398&ppt=C0331
10-oreillys
Water inlet tube: http://www.oreillyauto.com/site/c/de...6484&ppt=C0331
20-oreillys
Water neck: http://www.oreillyauto.com/site/c/de...0420&ppt=C0331
9-Oreillys
Bypass hose: http://www.oreillyauto.com/site/c/de...1382&ppt=C0331
5- oreillys
Plenum kit: http://www.ebay.com/itm/DODGE-JEEP-ALUMINUM-PLENUM-PLATE-BELLY-PAN-318-360-5-2-5-9-MANIFOLD-REPAIR-KIT-/200955988334?pt=Motors_Car_Truck_Parts_Accessories&hash=item2ec9e9096e&vxp=mtr 60-eBay
Intake bolts: http://www.summitracing.com/parts/dc...iew/make/dodge
13-summit
Cap and rotor: http://www.summitracing.com/parts/sum-g5233/overview/
24-summit
Plug wires: http://www.summitracing.com/parts/ta...iew/make/dodge
32-summit
Spark plugs: http://www.summitracing.com/parts/bch-7927
12-summit
Cai: http://www.summitracing.com/parts/sp...model/ram-1500
150-summit
O2 sensor: need to check connector style, get NTK or Denso brand
40?
Coolant sensor: need to check if 1 or 2 terminals
15?
Intake sensor: http://www.oreillyauto.com/site/c/de...2202&ppt=C0033
20-oreillys
PCM: http://www.summitracing.com/parts/dc...model/ram-1500
266-summit
Dipstick tube: http://www.amazon.com/gp/aw/d/B00837RVVI
16-amazon
Oil: http://www.summitracing.com/parts/cca-1590/overview/
30-summit
Total: $2480
Old Feb 23, 2014 | 08:11 PM
  #85
Make sure whatever heads you get will tolerate the lift on that cam.
Not replacing rockers?
You have two coolant temp sensors on your engine. A one wire, that does the gauge, and a two wire, that the PCM pays attention to.
Old Feb 23, 2014 | 08:37 PM
  #86
snowboundrmk
The heads are thicker casting stock size valve odessa's that will be built for the cam. I'm going to get Harland Sharp 1.6 rockers eventually but that is a lot more money to add, so I might not get them right away. I didn't realize I had two coolant sensors so I will add those. Are they both on the intake?
Old Feb 23, 2014 | 09:06 PM
  #87
FireDodge's Avatar
FireDodge
That's the cam I'm running! You're gonna like it
Old Feb 23, 2014 | 10:23 PM
  #88
Yep, both on the intake, one just outboard of where the heater hose hits the manifold, and the other just to the drivers side of the thermostat housing.
Old Mar 8, 2014 | 07:42 PM
  #89
snowboundrmk
The aluminum plenum plate for $60 is no longer on eBay. Is there someone else who makes them? I don't really want to pay $120 for the Hughes one which comes with extra stuff I don't need.
Old Mar 8, 2014 | 07:49 PM
  #90
Johnn123's Avatar
Johnn123
Drop the cold air intake, theres half the funds for the HS rockers. CAI is useless.
Plenum plate not sure bud, I think Hughes might be your only option left. I got that kit, I like it, still holding up well after a year.
Might consider trying to contact the member who sold the plates on ebay and see if he will be making more of them. Builds coming along nicely dude! You're gonna LOVE that Mopar PCM!
