99ram transmission type
Old Sep 3, 2013 | 12:42 PM
dodge_chris's Avatar
dodge_chris
Default 99ram transmission type
__Hello, I appologize in advance if this is an age old question. I have a 1999 dodge ram 1500 5.2l v8 2WD automatic. The transmission began slipping so i removed it to swap it out. I have a few potential donor trucks that i am looking at buying to swap transmissions I've been told by several people that there are a few different types of transmissions for the same model truck. what i've found online is a 96-99 dodge ram 5.2l 2wd auto will fit. I am just looking for someone to confirm what transmissions will fit my truck. Thanks
Old Sep 3, 2013 | 12:44 PM
stewie01's Avatar
stewie01
1994-1996 (some of the '96 anyway) where 46RH. Some of the '96 and up are 46RE.
Your '99 is a 46RE, so just get another 46RE. Closest to your year is preferred....
Old Sep 3, 2013 | 01:33 PM
Johnn123's Avatar
Johnn123
46re is the transmission you have now. 96-01 46re should bolt right up but as Stewie said get as close to your year as possible. A 42re or 44re may bolt up but they're not recommended as they're even more frail then the 46re is..
Old Sep 3, 2013 | 02:19 PM
dodge_chris
Thanks. So if I find a 96-01 ram 5.2 2wd auto the trans will be a 46re? Just want to keep from buying a donor with wrong transmission. Thanks again.
Old Sep 3, 2013 | 02:28 PM
Johnn123's Avatar
Johnn123
Should be. Get a build sheet for the donor before you buy it just to be sure though. That or ask the seller to get you a build sheet, then you'll know for sure.
Old Sep 3, 2013 | 02:30 PM
5.2 or 5.9 will work. Both use the same trans.
Keep in mind, in 2000, connector pinouts changed, so the 00 and up won't be a direct drop in/hook up, and expect it to work. Would need to change out the electrical stuff to get TCC, and O/D to work properly. So, 96-99 out of a V-8 2wd is your best bet.
Old Sep 3, 2013 | 02:32 PM
Johnn123's Avatar
Johnn123
I did not know they did that thanks for the heads up!
Old Sep 3, 2013 | 02:50 PM
stewie01's Avatar
stewie01
Easy way to tell would be the connector on the driver side. From another thread here 3 pin should be RH, 8 pin should be RE.
Old Sep 3, 2013 | 06:00 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Yes, but that only tells you if it's an RH or RE . You still need the correct year tranny for it to be plug and play as Heyyou stated.
Old Sep 3, 2013 | 06:15 PM
stewie01's Avatar
stewie01
Yes....... But more important to know right off if it's an RH or RE... If one screwed up and got a newer trans worst case you have to buy new sensors to make it work....
Edit: 1997-1999 should be complete plug and play. 1996 is a split year, need to verify it's an RE before you purchase....
