Rebuild Instead of 440 Swap
Old 10-08-2013, 10:12 AM
80Adventurer150's Avatar
80Adventurer150
80Adventurer150 is offline
Originally Posted by ryan0714
i dont have have an egr anymore. and whats so special about that timing cover gasket? the one i have on it is fine so far...think i used felpro
That gasket is brutus and worth every penny. Get one and set it beside the Felpro and you'll understand.
Last time the one from my Sealed Power gasket set blew out, I ended up pulling the motor to get things in order. So I got tweaked a little.
Old 10-08-2013, 11:47 AM
merc225hp's Avatar
merc225hp
merc225hp is offline
I have to agree on this, the Mopar performance gaskets are the ****. Thing is these gaskets are not getting replaced by Ma Mopar once they are gone they are gone. I think RnR might have got the last of the full rebuild gasket kits, and I think he found that a Summit racing.
Old 10-08-2013, 05:50 PM
ryan0714's Avatar
ryan0714
ryan0714 is offline
cool cool ill look into it.
and you guys got any guesses on numbers my engine my be throwin out with the parts i listed... just for fun...
Old 10-09-2013, 10:52 AM
80Adventurer150
stock heads?
and OBD1?
I would hope for 300hp/400tq. Pretty sure the SBEC Holley EFI won't support more than 300hp.
Old 10-09-2013, 12:08 PM
ryan0714's Avatar
ryan0714
ryan0714 is offline
I have the same fuel injection as yal do on your rams. Nothin different about this motor other than being obdI. I was hoping for closer to 350-375ish hp. But I'd be cool with 300 hp and 400 tq
Old 10-09-2013, 01:22 PM
80Adventurer150
The stock computer probably won't be able to take much advantage of the big cam.
Old 10-09-2013, 02:21 PM
HeyYou is offline
Dodge Forum Administrator
Received 3,270 Likes on 3,017 Posts
If the cam is too big, it will annoy the computer, and it will run like doo doo.
Old 10-09-2013, 02:47 PM
merc225hp's Avatar
merc225hp
I can't find part numbers for the Mopar P pcm for that year of 5.9 truck, 5.2 Jeep Grand Cherokee, and the 5.2 Dakota yep, the op might look deeper to see if there is one out there that I don't have a part number for. Other than that B&G or a stand alone setup.
Old 10-09-2013, 07:44 PM
ryan0714's Avatar
ryan0714
ryan0714 is offline
shouldnt need it, that cam is designed to work with an all stock magnum motor. but thanks for the input, i thought about a mopar pcm
Old 10-10-2013, 12:21 PM
80Adventurer150
Is B&G still doing OBD1 stuff?
Quick Reply: Rebuild Instead of 440 Swap
