Chips and tuners for 1996 Ram 5.9 gas
Old Nov 5, 2014 | 11:13 AM
Rammann's Avatar
Rammann
Default Chips and tuners for 1996 Ram 5.9 gas
Ok new to the forum hope someone can help just put headers on and check engine light stays on I think it the O2 sensors. Would like to chip it also but having a hard time finding a tuner (chip) for this year I'am all ears for help!!!
Old Nov 5, 2014 | 11:25 AM
1997JollyGreenGiant's Avatar
1997JollyGreenGiant
HemiFever has a tuner that will work for a 1996. It removes torque management on the engine. He has canned tunes and custom tunes available.
You can probably drive your truck to Autozone and they'll read the Check Engine Light for you.
How many miles are on the truck? Is the plenum fixed? Is it the original O2 sensors? If you do replace them, go with NTK, but don't do it until you fix your plenum.
Is the truck 2WD or 4WD? Shorty Headers are easier to install, just bolt them in. The Long Tubes can be difficult. I believe you run into clearance issues on the 4WD trucks if using Long Tube headers. You can modify them to work though.
Old Nov 5, 2014 | 12:10 PM
If you search, you will find lots of info.
https://dodgeforum.com/forum/2nd-gen...22-tuners.html
https://dodgeforum.com/forum/2nd-gen...ance-chip.html
https://dodgeforum.com/forum/2nd-gen...or-3842-a.html
https://dodgeforum.com/forum/2nd-gen...ave-2-gen.html
Old Nov 5, 2014 | 03:28 PM
Do you have both O2 sensors installed?
Old Nov 5, 2014 | 04:40 PM
Rammann's Avatar
Rammann
yes I have both installed
Old Nov 5, 2014 | 09:31 PM
Need to read the codes, and see what it is whining about then. Most auto parts stores will do that these days. It may just be whining about cat efficiency, and there is a workaround for that.
If by "chip it", you mean "install one of them two-wire 'chips' that go in the IAT circuit", don't bother. Its a waste of money. The claims are lies. The ONLY way to improve power/efficiency via the electronics, is with a tuner, that reprograms the PCM. Anything else is snake oil.
