Jet thermostat?
Old 10-08-2015, 11:52 AM
jkeaton is offline
Dodge Forum Administrator
Originally Posted by Khris1994
Well I understood that. I just figured shouldn't there be something that kinda blocks the water from bypassing the radiator? I'm not very knowledgable on cooling systems.
In this day and age, knowledge is just a click away...
http://auto.howstuffworks.com/cooling-system.htm
Old 10-08-2015, 01:17 PM
Khris1994's Avatar
Khris1994
Khris1994 is offline
Gotcha heyyou. That makes sense. The water pump sucks through the radiator instead of needing a block off to force water through.
Old 10-14-2015, 05:25 PM
Khris1994's Avatar
Khris1994
I hate bringing dead posts back but turns out the temp gauge is wrong. Seems to be off by 18* as it still says 200 with the stant stat... Sorry jet stats... Well now I have a spare stat. What seems to be the most reliable brand temp sensor and sending units? Should I try the dealer? I just hate being ripped off by the dealers. I did put a dab of silicone on the threads to ensure seal... Could that be causing an improper reading perhaps?...
Old 10-14-2015, 08:19 PM
HeyYou is online now
Received 3,274 Likes on 3,021 Posts
Yep. Sure could. The sensor uses the intake as the ground side of the circuit. If you insulate it from that ground, you will indeed get an inaccurate reading.
Quick Reply: Jet thermostat?
