The Official 2nd Gen Ram OT Thread
Old 01-22-2017, 10:27 AM
Gary-L's Avatar
Gary-L
Gary-L is offline
  #492
Old 01-26-2017, 08:59 AM
1997JollyGreenGiant's Avatar
1997JollyGreenGiant
1997JollyGreenGiant is offline
Guess you lost the oil drain plug on your car Gary. You should put a spark plug wire on it and see what happens. ;-)
  #493
Old 02-04-2017, 03:39 AM
BrandonBuc'em's Avatar
BrandonBuc'em
BrandonBuc'em is offline
im assuming ot stands for off topic?
  #494
Old 02-04-2017, 09:54 AM
HeyYou is online now
Dodge Forum Administrator
Received 3,191 Likes on 2,944 Posts
Correct.
  #495
Old 02-04-2017, 01:37 PM
Gary-L's Avatar
Gary-L
Gary-L is offline
  #496
Old 02-04-2017, 01:38 PM
Gary-L's Avatar
Gary-L
Gary-L is offline
  #497
Old 02-17-2017, 12:21 PM
Wildman4x4nut's Avatar
Wildman4x4nut
Wildman4x4nut is offline
So Rusty's Off-Road has just came out with these new ball joints. It will be interesting to see how they hold up once rigs start getting them installed. Because they fit the D44 Jeep axles I am going to SWAG it and say they should also fit our D44 axles .
http://www.rustysoffroad.com/jeep-dr...-mj-wj-zj.html
Yes $600 for the set is steep but if they last 2x or 3x as long as stock joints they would be worth it.
  #498
Old 02-17-2017, 01:33 PM
Wow. Nice, but, definitely pricey.... Are you going to have clearance for the lowers between that tower sticking up, with the zerk fitting, and the U-joint??
  #499
Old 02-18-2017, 01:44 PM
Wildman4x4nut
I'm not sure what you will have to do to make room. Until we all see a set installed on a axle it's all just speculation.
  #500
Old 02-19-2017, 09:30 AM
Gary-L's Avatar
Gary-L
Gary-L is offline
Hey guys (and gals), I need some help:
I have a 2006 Mazda 3 with the 5-speed auto. I went through the steering, suspension, and a lot of regular engine maintenance last year and had the car running great. Come this past December, the transmission started acting up and has thrown a code (Shift Servo E Stuck Closed). Here is a link where I posted the issue on a Mazda forum. The pump whines line a 2-year old on start-up, so I'm guessing there are some internal issues.
My main problem is finding a rebuild manual for the FNR5 transmission. Ford uses a variation of this transmission, so I cannot use the Ford version. I found a great video, on YouTube, where the tech walks through teardown and rebuilding of the transmission. I figure I can do the job for under $1,000 (including upgraded parts) versus $2,500 for a professional.
I would appreciate it if anyone can assist with sourcing a manual.
Quick Reply: The Official 2nd Gen Ram OT Thread
