99 46re dies in reverse
Old Jul 4, 2018 | 11:59 AM
wcc1944@yahoo.com's Avatar
wcc1944@yahoo.com
Default 99 46re dies in reverse
it sounds and appears to immediately run lean when put in reverse and it dies. when you are driving it feels like a miss at certain points when it is in overdrive it bucks sometimes
Old Jul 4, 2018 | 12:16 PM
Any codes? Sometimes, those are signs of a dying crank sensor.
Old Jul 4, 2018 | 12:30 PM
wcc1944@yahoo.com
no codes at all it shifts great in every gear but sometimes buck jumps like a intermittent miss in od but it has zero codes
Old Jul 4, 2018 | 12:33 PM
wcc1944@yahoo.com
sometimes it will go in reverse at exact idle but if you give it any throttle at all it seems like it starts running very lean and immediately dies. when you put it in park or neutral it starts back up but you have the smell of raw gas and smoke for a couple of seconds
Old Jul 4, 2018 | 12:34 PM
wcc1944@yahoo.com
it is a 99 5.9 4x4
Old Jul 4, 2018 | 12:53 PM
Does it always die in reverse? Does it stumble first, then die? Or is it like you just shut off the key?
Wonder if the shift linkage is pushing around a harness, or some such.
Old Jul 4, 2018 | 02:24 PM
wcc1944@yahoo.com
The truck cuts out for 3 o 4 seconds then dies I unplugged the big electronic feed and it still does it. I’m wondering if it is the TCC lock up and overdrive solenoid bad together
Old Jul 4, 2018 | 02:25 PM
wcc1944@yahoo.com
I also checked all the connections but nothing is rubbing or in the way of the linkage
Old Jul 4, 2018 | 02:56 PM
How old is the crank sensor?
Old Jul 4, 2018 | 02:57 PM
wcc1944@yahoo.com
Is there a possibility it could be the crank sensor
