Radio in 1998 1500
Radio in 1998 1500
Radio not working (lights up and shows stations and such), pulled and checked connections, all OK. After looking at past posts here thinking it must be amp in kick panel...before I could tear into that radio started working, as I went to adjust volume it quit working again and can't get it to fire up again. It must be the volume control,...Question is has anyone taken radio apart to fix a similar problem?
Don’t know if this radio is the Infinity model but it looks like this.... If I do tear into the thing pictures will follow, right now it is not on top of list of projects like changing broken shifter cable in Corvette; getting my 1971 Chevy 1/2 ton ready to sell; figuring out what is wrong with the 350 engine in boat causing it to backfire and not run; checking driveshaft and U joints on this truck that is making a weird noise and the Honey Do list my wife keeps adding to.
I recently had issues similar to you with my radio randomly working (no sound but everything else worked) with my factory infinity system. Replaced the head unit with an aftermarket just for it to totally quit after a couple days. So I did some tracing around and found out I didn't have power at my factory amplifiers. Turns out how the infinity system works is that there is two amplifiers, one on each of the front door speakers, that runs all the speakers on their respective sides of the truck. The power is delivered from what Chrysler calls the "choke and relay" that gets a signal from the head unit. From what I can tell its just a noise filter and relay, but they haven't made it since 2014. Once I finally find the choke and relay (I think its behind the cluster) I am planning on using a normal relay and a noise filter.
Trending Topics
