header warpped
RE: header warpped
depends on where its at.. if you notice on the header.. you got the tubes that meet up on each port from the head.. and then between each tube you have a connecter ... also called the flange... now the flange can warp out between tubes and still have a good seal.. this is VERY rare b/c usually when that section warps it will contract or expand the location of each tube..
are you expereincing any leaks right now?
fixing it.. pretty sure theres no way to fix it.. unless you can heat it up and pound it flat then re-square it with a mill or a belt sander.. alot of work for a questionable outcome.. what brand are the headers?
RE: header warpped
I had purchased a set of Summit/Pacesetter headers about a year ago. Pretty inexpensive but they burnt out very quickly.Use this link to see the photo's in my album. https://dodgeforum.com/albumphoto.as...amp;sortType=6Other people have used them without issue. I replaced the Summit headers with Edelbrock ceramic shorties (twice the price) and love them. Installation was a breeze and they look awesome.
Whatever brand you go with "DO NOT" use header wrap on them. First it usually voids the warranty, 2nd it will cause your headers to rust out from trapped moisture.
RE: header warpped
ORIGINAL: turkeyhunter1962
Trending Topics
RE: header warpped
The experience you have is exactly what I was attempting to do when I wrapped my headers originally. I also used DEI products when wrapping my Summit headers and you can see the results. In speaking with Summit and Pacesetter they both stated header wrap should not be used. Summit has changed their package notices advising that if you use any non-factory protective coating/covering the warranty is void. just passing along my personal experience on this one.
