Installed the smoked Recon Clearance Lights
Old 04-26-2007, 07:02 PM
Mayfair's Avatar
Mayfair
Mayfair is offline
Default RE: Installed the smoked Recon Clearance Lights
Hmmmm .... I may hafta re-think this again.
Did you guy's have the compass thing on your headliner? ( I do )
How difficult is it to remove the headliner? What's involved?
  #22
Old 04-26-2007, 07:46 PM
Glideman88's Avatar
Glideman88
Glideman88 is offline
There are two latch tabs inside the garage door opener compartment. Push both tabs forward to unlatch. them, the gently pull the console rearward to release it from the ceiling.
Simply unplug the wire harness and you're good to go!
  #23
Old 04-26-2007, 07:49 PM
Mayfair's Avatar
Mayfair
Mayfair is offline
I have a 98 .... I don't have the garage door opener thing. It just looks like a compass and a thermometer.
How about pulling the headliner down though. How do you do that?
  #24
Old 04-26-2007, 07:55 PM
JarheadX's Avatar
JarheadX
JarheadX is offline
kyle if you're gunna get rid of urs let me know, im lookin to get some if there is a good deal
  #25
Old 04-26-2007, 07:59 PM
Glideman88's Avatar
Glideman88
The headliner is fairly easy to remove too.
Download the link in this thread for a complete service manual with all the steps. https://dodgeforum.com/m_340929/tm.htm
After you have downloaded the manual, look in the BODY chapter, INTERIOR section, "headliner removal"
  #26
Old 04-26-2007, 08:02 PM
JarheadX's Avatar
JarheadX
JarheadX is offline
im removing my headliner, i need some suade... [8D]
  #27
Old 04-26-2007, 09:01 PM
jnellydodge's Avatar
jnellydodge
jnellydodge is offline
ORIGINAL: Mayfair
Its actually not difficult at all. That manual would have helped, i wish i woulda double checked on this website before going ***** deep into this project. The hardest thing for me was that stupid overhead compass, two screws in the front, and in there rear there are twoclips that hold it up and are VERY DELICATE, and the need to be removed at an angle. Other than that pretty much just pull or unscrew everything that hold it up and she'll come right out----once its down and seeing that you have afour-doorgetting itout of your truck will be easy for you.
Quick Reply: Installed the smoked Recon Clearance Lights
