Using Oil Where is it going?
RE: Using Oil Where is it going?
Sometimes if you've removed the intake and used the rubber gaskets on the front and rear they blow out and will cause a leak.Usually on the back of the intake,it will run onto the top of the bell housing and is hard to see.I always throw those gaskets away and just put a nice bead of high temp permatex in those areas.
I do all the oil changes and it's only been about a month. There's some oil gunked on top of the tranny but I thought it was the tranny vent. Could that be running down the bell housing onto the top of the tranny? I'll go look again. Thanks for the suggestion. So you're saying I shouldn't be burning oil?
ORIGINAL: flintspirit
Trending Topics
