rear drum brake *CHEAP UPGRADE*
Old Mar 25, 2009 | 12:16 AM
  #61
amundson360's Avatar
amundson360
does this work on 01's?... i'm confused. also, my drums seem to lock up at every stop sign and i can hear a grinding noise untill i'm up to about 10mph...what would this be? are the shoes not going back? how can i fix it?
Old Mar 25, 2009 | 11:29 AM
  #62
PurplDodge's Avatar
PurplDodge
The drums might need adjusting.
Old Mar 25, 2009 | 04:42 PM
  #63
pavement_hater's Avatar
pavement_hater
01''s already have the larger cylinder. The 1500 uses the same part # that a 3500 does. As far as the noise goes I would check the adjustment
Old Mar 26, 2009 | 08:48 AM
  #64
amundson360
thanks for clearing up the cylinder issue... as for the adjustment, i backed the little "star" adjuster down all the way, and it still does it, are the springs just not pulling the shoes back?
Old Mar 26, 2009 | 09:40 AM
  #65
ron333's Avatar
ron333
Anybody doing this on a truck with a lift kit using lift blocks in the rear, be prepared for wheel hop under heavy braking! I did this modification a few months back, and I'm glad I did! It has saved me from crashing already! I had to slam on the brakes the other day, and I at first couldn't understand why the rear end started bouncing as the truck came to a stop. Then I came to the conclusion that what I was experiencing was leaf spring wrap due to the amount of stopping power my rear brakes have. They didn't lock up, just felt like they were holding, releasing, holding, releasing but so much so that the rear end started softly bouncing. I did stop just in time to avoid a major collision! Thanks to the members of this forum for helping save my truck!!!
Old Mar 26, 2009 | 10:06 AM
  #66
Gary-L's Avatar
Gary-L
Veteran: Navy
  1. Remove the drums and get to the root of the problem.
  2. Ensure the shoes aren't installed incorrectly. I did that the first time.
  3. With the shoes installed properly, they should be adjusted to slightly drag the drum once the drum is reinstalled.
Are you seriously running a TB Spacer? Toss it into the trash!
Old Mar 26, 2009 | 11:12 AM
  #67
TMS Bill's Avatar
TMS Bill
Not exactly the same improvement ... in '01, Dodge reduced the size of the wheel cylinders for the 3/4 and 1 ton trucks and then matched the 1/2 tons to them. The cylinder diameter is only 1" ... just 1/16" larger than the 15/16" they used to be. The Chevy 1 ton dually cylinders are 1 3/16" ... a HUGE jump over the original size ... and still a major increase over the "new and improved" '01 series.
Old Mar 27, 2009 | 11:51 AM
  #68
J415's Avatar
J415
Glad to hear you made it out without crashing. So did you use the Dodge 1 ton wheel cylinder with the 1 1/16 inch bore or the Chevy Dually cylinder with the 1 3/16 inch bore? just curious what result people are getting with the different cylinders.
Old Mar 27, 2009 | 04:03 PM
  #69
ron333's Avatar
ron333
I used the Dodge 1 ton cylinder. Definitely works better than original one, and thank you.
Old Mar 29, 2009 | 07:08 PM
  #70
PurplDodge's Avatar
PurplDodge
I also did this mod with new drums, shoes, and springs. Now I can feel the truck acually stopping, and the truck stops quicker and shorter. I used a 1999 Dodge 1-ton wheel cylinder.
