Violent front end shake 94 Dodge Ram, 1500
Old Nov 13, 2007 | 12:12 PM
padodgeram's Avatar
padodgeram
Default RE: Violent front end shake 94 Dodge Ram, 1500
we sound never assume...lol...doh !!!!
Old Nov 13, 2007 | 11:01 PM
aim4squirrels's Avatar
aim4squirrels
at least he made good with the details, hehe.
How old are you're shocks? The shocks are repsonsible for "calming" the springs down after they absorb an impact.it sounds like your shocks might be so bad your just riding on springs.
Somebody just posted a little bit ago about replacing their whole damn front end and in the end it was worn rubberbushings. If you're going to start somewherebesides the shocks, I'd recommend swapping these first to save money. Energy Suspension make a great polyurethane replacement.
Old Nov 14, 2007 | 09:38 AM
br3ktw's Avatar
br3ktw
Its hard to date the shocks. I could speculate that they are original equipment. How would I determine if I should replace them or not?
Old Nov 14, 2007 | 05:38 PM
br3ktw's Avatar
br3ktw
Exactly which rubber bushings are you referring to?
Old Nov 17, 2011 | 06:32 PM
bms's Avatar
bms
hi i have a 2001 ram with with a bad vibration in the front end over 50mph had it before and changed the track bar and it went away. but know its back i just got done changing the track bar and sway bar end links. changed the sway bar bushings about 6 mounths ago. the tie rods seem to be all tight. it a biger bump and a little higher speed but it still has the bad vibration. could it be the bushings in the control arms or what the hell can i do to fix this?
Thanks.
Old Nov 17, 2011 | 06:36 PM
bms's Avatar
bms
oh and i put new front shocks on 2-3 months ago.
Thanks.
Old Nov 17, 2011 | 06:48 PM
Rotate your tires, see if the vibration is any different.
Old Nov 17, 2011 | 10:33 PM
jswain's Avatar
jswain
On 4wd's (doubt 2wd's react the same, since they don't have a solid axle), I have noticed that low tire pressure on one side or the other can cause the tires to bounce back and forth (it feels like the tire on one side bounces, the other side bounces, back and forth) when you hit a decent bump at speed. I've had this happen several times over the years, only to find a had a low tire and inflating both tires to the proper level would alleviate the problem. That is the first thing I'd try, make sure tire pressure is correct and equal on both sides. If that doesn't work, then delve into trac bars, bushings and such. You might get lucky and have an easy fix. 174k miles here, original shocks, bushings, trac bar, ball joints, etc.
