Severe gear whine...
Old Nov 16, 2009 | 10:34 PM
  #31
silverbullet-dodgeram's Avatar
get ur gear spacing checked
Old Nov 16, 2009 | 10:35 PM
  #32
dodge15004x45.9's Avatar
dodge15004x45.9
Yep when I do my 4.56 I'm just going to lock the rear and leave the front open. Than I need to find some 4x3 stickers lol.
Old Nov 16, 2009 | 10:38 PM
  #33
95RAM360's Avatar
95RAM360
it kinda sucks when you think about it...i have open front/rear...so technically i have a 2wd...but i think the stock gears had the lsd. can you use the lsd when you change the gears to 4.10? or do you hae to get a different one? maybe thats why mines an open, becuse i thought they all came stock with LSD
Unless the LSD is what blew, then when he changed the rear end he just got the 4.10s and didnt get the LSD
Old Nov 16, 2009 | 10:40 PM
  #34
dodge15004x45.9
Our factory lsd can run put to 4.88 gears size. Odds are your might have been blown or it never had one.
Old Nov 16, 2009 | 10:42 PM
  #35
95RAM360's Avatar
95RAM360
i think it blew and thats what killed the rear end which prompted the PO to get 4.10's...he was a mechanic and kept every recipt...I have all the recipts from 108K is the earliest one i have. probably like 100 recipts total. they were for everything, oil, air filter, tranny, 4.10s etc.
Old Nov 22, 2009 | 10:26 PM
  #36
infringer's Avatar
infringer
Default On my 3rd rear end in 96k miles
Once the pinon is lose it will chew up gears it is very visual if you remove the cover...
The wine can also be attributed to bad ujoints a metallic grinding sound...
I am currently in the process of doing something I do not recommend to anyone myself slapping a dana 70 3/4 ton from a 2500 into a 1500 shocks lineup nice but the plates on the axle that mount to the leafs are too wide and about 2 inches off ... gotta love it!!! shoulda coulda woulda stuck with half ton but this sucker is all rebuilt with posi gears and new break hardware just waiting for a truck to sit under... Life sucks have a TransAm from 82 and two 86 camaros and a 2006 ford fusion that all need work as well...
Life is good 5 vehicles none are functioning correctly
yey!
