Newbie with a coolant leak
I inherited my dad's 1995 Ram 1500. It has close to 200,000 miles on it. I want to keep it on the road in his memory, but it's starting to nickel and dime me to death.
Anywho...we had 4 straight nights of teen temps and I started noticing coolant on the driveway...just small spots. I climbed under the truck and saw a slow leak from the bell housing just behind the oil pan. The leak seems to be growing. I can't find any coolant topside. So far, the leak isn't bad enough that I can smell coolant.
Are there coolant hoses at the rear of the engine (5.2)?
If I have a busted water jacket, what will that mean $-wise?
Could there be another cause?
Thanky
Thanky
RE: Newbie with a coolant leak
If it's a cracked head, wouldn't I have coolant in the oil? (don't as of yet)
I am getting rusty core plug advice on another site.
Where exactly would I look for an intake leak?
I'm not a gearhead, so would it be best to take it to a stealership or a trusted hometown shop?
Thanky'gin
Thanky'gin
K...just crawled under the front end of the truck and it's a corroded core plug about the size of a 50-cent piece on the driver side. The coolant is pretty old, so it may be acidic. I think I'll put a bandaid on it...flush the radiator and add 2 packs of Aluma-seal...whaddyathink?
Can a core plug be welded shut in place? Or should I try to grind it out and use an expanding rubber/nut-bolt plug? JB Weld?
Thankyx3
Thankyx3
Trending Topics
