LT Headers+Y-Pipe in..I feel I lost some torque?
#91
wow....that setup is like **** on a bull. Why in Gods good name do you have a Y pipe if you are running fake dual exhaust after that? The cat is in the stupidest spot, the welder is obviously mildly mentally challanged, and o2 wires can be extended just like any other wire.....this is rediculiousness.....[sm=bangbang.gif]
#92
#94
He said he shaved some of them down that he couldn't get out, and some that broke he was still able to get out. I don't know, he didn't make me feel good about the project. He just bitched that it was a hard job, and how tough it was to get the manifolds out. I left the place feeling like ****, and it wasn't something I should have felt like after working so hard to get these headers and to pay for those to be put in...I want him to fix the cat positioning ASAP.
#95
ORIGINAL: IndyRamMan
....and o2 wires can be extended just like any other wire.....this is rediculiousness.....[sm=bangbang.gif]
#96
#97
i worked at a muffler shop once and never seen any shady work like that done before, plus the fact that he broke the bolts off and shaved them down??? wtf????woooof!!!!! if i saw that i would of told him to stop what he was doing and took it somewhere else, sorry
#98
ORIGINAL: Silver_Dodge
Not necessarily. An o2 sensor works by creating a chemical reaction that generates a voltage. The PCM looks at that voltage reading to determine if the mixture is rich or lean. It adjusts the mixture based on these readings. Splicing and extending wires (even a good soder and heat shrink splice) will introduce resistance, which could change the final voltage reading the PCM is seeing. This means the PCM is making it's mixture adjustment based on a reading that is not accurate. For example, the output voltage of a narrow band o2 sensor when the a/f is perfect (14.7:1) is about .45V. Changing the voltage by as little as +/- .4v puts you into a pretty good rich condition (.85v = a/f around 13:1) or lean condition (.05v=a/f around 17:1).
EDIT:: I dont mean putting the cat in the proper place will make a diff in resistance, i mean in the proper reading. What Im saying is its the lesser of two evils.
#99
if you could take more pics i can take them to my friend who's been in the business for 28 years doing the same thing over and over (exhaust that is) and see what he would of done, just a thought and a different opinion might help when you go to call the guy who did your exhaust
#100
