Old Aug 7, 2015, 12:55 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Engine
Print Wikipost
Kegger Intake Mod DIY
Old Feb 26, 2011 | 10:35 AM
  #171
Randy_W's Avatar
Randy_W
Sounds like a super charger to get that kind of whp from a 318 and still keep it drivable.
Old Feb 27, 2011 | 07:14 PM
  #172
atthewmartin114's Avatar
atthewmartin114
310 rear wheel horsepower??? What engine mods do you have?
if you look on any dodge dealer specs the dakota are like 320 hp off the factory floor in 1997 then tuned them down in 1998 because they kept destroying the dana 35s and the transfer cases
Old Feb 27, 2011 | 07:27 PM
  #173
Not from any information I can find....... Highest I see is 250 for the 5.9 liter.
You also need to bear in mind manufacturers ratings are FLYWHEEL horsepower. You can expect somewhere in the neighborhood of 30% power loss thru the driveline. (especially with an automatic trans.)
Old Feb 28, 2011 | 10:14 AM
  #174
Silver_Dodge's Avatar
Silver_Dodge
Ya, i've never seen anything that said a Dakota had 320hp in 1997, not even at the flywheel.
Old Feb 28, 2011 | 10:16 AM
  #175
nolazach's Avatar
nolazach
Wow this thread is bumped...
This one is one of the first DIYs I used here..
Back in 2008.
Glad I got rid of the crappy stock plenum, and did some kegger work..
Old Feb 28, 2011 | 02:26 PM
  #176
HDRAMman's Avatar
HDRAMman
Anyone ever see these modded and sold? Or has anyone ever sold them modded?
Old Feb 28, 2011 | 02:45 PM
  #177
Silver_Dodge
KRC or Hughes sells one if i remember correctly. They fill theirs too (or put in some sort of turtle).
Old Feb 28, 2011 | 03:41 PM
  #178
Hughes sells them, as do a couple members here on the site. Check the classified section.
Old Feb 28, 2011 | 10:40 PM
  #179
atthewmartin114
and excuse me i stand corrected that 210hp i looked at the print outs again they are about 3 years old. and its 290 tc
Stock was 230 hp and 300 tc
here is the specs website: http://autos.msn.com/research/vip/sp...ota&trimid=280
And after i reinstall said motor with Silvers intake mod and 180 stat aem tb spacer and aem 4.5 inch cold air with a k&n intake filter. im still running stock manifolds because the headers are in the oven getting ceramic coated. the only other mod i have done with the truck is in the computer it has been reprogrammed to allow for the specs of the 1998 r/t fuel curve (tho it only waste fuel being im running the nv3500 tranny) i have also stripped as much weight that was unless as possable also converted from the 22 gallon gas tank to the 15 gallon tank.
Old Feb 28, 2011 | 11:24 PM
  #180
bekins01ram's Avatar
bekins01ram
Forgive me if i'm just reading incorrectly, but, "headers are in the oven getting ceramic coated." Does this mean, this is something I can do on my own with a set of stainless headers? Because I'd be more then happy to ceramic my own headers, even if it stinks up my house, as long as it saves me a couple hundred dollars.
