HOW MUCH OIL IS TOO MUCH ?
ORIGINAL: IndyRamMan
Incase you didnt know....non synthetic oil was starting to be made about 100,000,000 years ago. Its the same oil today as it was 30 years ago. If your talking about refinement processes, ok then. I will give you that the oil is more pure, and possibly more additives. BUT the oil is STILL and always will be the same base product. Most of the additives are chemical cleaners that stop gunk buildup, they dont desintegrate debris. If nothing else you should change it because no matter what mobil 1 says their filters do not continue to filter at the same capicity after ~3000 miles that it does before.
ORIGINAL: TheForce55555
hmmm..............................oil of today is better than what we had 30 years ago
but you didnt.
what in the world would make you think that more than 3000 miles is appropriate? Because we have iPhones and cars that park themselves?
ORIGINAL: Ram2K1
Theoretically, you could change your oil at 6K and your filter at 3K...as a sort of compromise. I just changed my oil after 3 months and had only driven like 2K miles.
but you didnt.
#1. The oil be synthetic
#2. The can used to catch the oil has never been used before and is totaly clean
I still wouldnt run synthetic much past 4500-6000 miles depending upon stresses of the motor (driving style)
That would make sense, but I would prolly just let the lost oil go and top it off with fresh.
Just guessing but, I take it you don't buy into the oil that Mobil 1 makes, guaranteed to protect up to 15K?
ORIGINAL: Ram2K1
Thats a really good bit of marketing there. That nonsense was devoloped to put women at ease. Its actually some of the BEST marketing in the last 10 years for new cars as far as Im concerned. The idea behind the so called "protection" that they offer is that the chemical additives (such as tefflon) that can clean/keep clean for the 15k lifespan. The oil, though synthetic, does not appear to have been engineered any diffrently than other synthetics. The first time the 10k/15k oils debued were in NEW production cars from the likes of GM and BMW. Women do not tend to like regular maintence and to hear that they only need to change the oil every 15k is a huge selling point to prospective buyers. Since 54% of the united states is female, this goes a long way to hit their demographics right where they want it.
That's a good point... I would never go over 6K/6 months anyway, but what about Amsoil? They say normal driving = 15K/1 YR. They seem to be very reputable with a long history in the synthetic business. I just couldn't stand it that long. Even at 6 months, I will check mine after 3 to make sure it still looks good/feels good. My Dad always told me, son, the life of your engine comes from regular oil changes... Now many years later, I tell my wife the same thing...no kids to tell yet...
ORIGINAL: Ram2K1
if the oil is doing its job, it should be dirty. looking at it won't accomplish anything. change ur oil, its cheap insurance.
Its basedon experience, knowledge andfacts backed by Independent used oil analysis.
Modern engines run cleaner, have better venting systems and are built with longer lasting components.
Fuel and engine oils are refined to much better standards. Most of the pollutants and trace elements have been removed and don't contribute to oil degradation like they used to.
Oil filter efficiency has also increased.
Even most factory oil monitoring systems don't recommend 3k oil changes any more.
Teflon in Mobil 1??? Who told you Teflon was a cleaning agent any way?
ORIGINAL: zddp8868
ORIGINAL: Ram2K1
i hear you...but i trust fully synthetic oil for 6K/6 months...
If you really want to know how well It's protecting take a sample and send it out for testing. It only costs $20-$25.
http://www.blackstone-labs.com/standard_analysis.html
They will analyse the oil and make recommendations based on what they find.
I recently went 13k on mass market synthetic and 1 filter
and all was fine. They said 15k would probably be fine if I wanted to try it next time.
I've seen reports from Walmart oil that went 6-8k no problem with a $2 filter (Walmart)
ORIGINAL: rabbler
I believe that using synthetic oil and a Napa Gold (or other) filter will be fine for 6K/6 months... I don't care if it would last longer, cause I like to change my oil and 6 months is as long as I can wait.[8D]
