Transmission***UPDATE
Old Mar 16, 2008 | 11:38 PM
  #391
05DodgeRamHemi's Avatar
05DodgeRamHemi
Default RE: Transmission
HAHA where the hell do you live?!
Old Mar 16, 2008 | 11:41 PM
  #392
hometheaterman's Avatar
hometheaterman
I live in VA too but I'm not sure how far Suffolk is away from me. Not exactly sure where that is in VA.
Old Mar 17, 2008 | 01:25 AM
  #393
dodgerules86's Avatar
dodgerules86
ORIGINAL: XXL 1500
in my garage at home (ON THE FLOOR) - i can have trans out in less than 3 hours.. with 0 power tools...
it takes 3 hours for a diesel 47RH 4x4...
... I had that in just trying to remove the crossmember under the transmission .
I just finished my 9th day working on my transmission change. Everyday brings about another unique problem. Luckily, I should have everything fairly well put back together tommorow. (I said this 2 days ago [&:]) Next time around (which, there shouldn't need to be one) things should go much quicker.
Old Mar 17, 2008 | 01:40 AM
  #394
kowboydmac's Avatar
kowboydmac
A DIY of an auto 46re would be cool.
Old Mar 17, 2008 | 02:09 AM
  #395
dodgerules86
My Dakotas got the 42RE, but regardless. I don't know how much of a differance a trans change is in a Ram vs. Dakota. All I know, it is kicking my ***. Especially trying to seperate the transfer case from the transmission, that was a pain.
I seriously was thinking it would only be a 2-3 day job (of course, I'm not the fastest worker), but working on stuff that hasn't been touched in 12 years isn't always "ideal."
Than again, if I only counted the time actually working (not spend on parts runs, eating, searching for tools, or standing with my arms crossed with the "how do I work around this?" thought in my head) I probably put in 4 days.
The best part is, I'm on vacation from work. This is how I spend my vacation, working on my truck. So yes, I'm a little crazy.
Old Mar 17, 2008 | 08:52 AM
  #396
securtis12's Avatar
securtis12
I just got mine put in about 9 hours in and out those crosmembers are a pain but if you pull the mount out first and then convince it back to the pockets in the frame it does not come out too bad. By the way this Dr. Evil trans rocks it is so sweet I can not believe the difference.
BTW my favorite part of the trans change was the brilliant engineer who came up eith putting a bolt behind the oil filter good thing I needed to change my oil anyway!
Old Mar 17, 2008 | 12:52 PM
  #397
dodgerules86
ORIGINAL: securtis12
Yea, it would have been a lot easier if the trans mount wanted to come out (the bolts holding the mount to the brace, and the brace to the trans were froze in place). Instead, I had to jack the trans as far as it would go up, and work out any problems from there.
And true about that bolt by the oil filter. Unfortunatly, I installed an oil filter bypass, so I had to disconnect lines instead of just spinning off a filter. Getting that torque converter dust shield off with the trans still semi-in-place didn't work either. I had to cut the new one in half to install it.
Old Mar 17, 2008 | 01:50 PM
  #398
nolazach's Avatar
nolazach
Joe.
I know we had a little tiff a while back, but really you remind me of my neighbor Jesse. He is the same way, nice truck, everyones go to guy with sound and appearnce mods. Yet he won't even change his own oil. He thinks he can't do it so he dosen't try. I think mechanic's as with almost all skilled jobs, are learners more than do'ers. You have to be willing to learn as you go. No one can just "do it". I had issues with my starter bolt and my crankshaft bolt, other than that all the work I did was "simple". Like you I had my truck up for nearly a month.
It started with a blown water pump, then Silver's (Reid) thread on the kegger made me want to look into the plenum. My plenum was bad so I pulled the intake. It isn't hard you just have to keep everything organized.
I like to keep a box of zip-lock bags with me and use a new bag with every new set of bolts.
Mainly when you come across a snag, post on here. EVERY QUESTION I HAVE HAD HAS BEEN ANSWERED HERE.
I would have been stuck if I did not have this site or the "merry christmas" thread.
I can't see paying $600 to get the intake gasket done. I also can't see doing it in a day.
You WILL come across other problems, bad sensors, needed parts whatever. I say spend a weekend doing it. You almost don't even need a big craftsman set just a 10mm-18mm set. Most of the bolts are either 12 or 14, I think.
It wasn't hard. You will gain more respect for your truck, you will learn a new skill, you will be better at diagnosing problems, you will save tons of money. Just take your time, don't rush it. The intake would be easy for a beginer and I now look skeptically at the poster who paid $660, yet gives mechanic advice:shrugs:
I also changed every engine gasket and inspected my heads. I did it when I had time and maybe total I spent 25 hrs but that was over three weeks.
Also sorry to hear about your tranny, that is the last fronteir for me; the only thing i DON'T TOUCH.
Old Mar 17, 2008 | 02:34 PM
  #399
hometheaterman
ORIGINAL: nolazach
You don't see me giving advice on how to do that or how to build a engine. I can do basic things myself and probably wouldn't have had a problem doing that I just wanted to have this guy do it since I knew it would be done right. Should I have done it myself? Probably but I wanted it done right and didn't have the time I wanted to spend on it either. I have never done one before so who knows what would have gone wrong and after looking over the DIY didn't really want to do it myself. I don't give advice about things I don't know about only about the things I know.
Old Mar 17, 2008 | 02:59 PM
  #400
05DodgeRamHemi
ORIGINAL: nolazach
Joe.
Thank you Zach. I can tell you are sincere with you say, and I agree with you. Not only will I gain some respect with the forum, but gain some respect with myself. It bothers the hell out of me that I know ABOUT all this crap, but I never try to attack it myself. I think your right, you just have to go for it. I'd like to get my truck back and enjoy it for a little while, but when it starts to warm up, and I can get a nice week to work on it, I'd like to try the plenum with my brother, I know he'll be willing to help me. We are both crazy into vehicles, it's our other life. I want to see if he'll help me get some tools, and help me out. I'll pring the DIY instructions on the plenum, and have a haynes and chilton manual for backup. If I get stuck, I'll consult to the forum for guys to pitch in with some pointers and solutions. Can't wait to try it, I'm really looking forward to it. I was planning on having someone install my fricken Fastman for christ sakes. If I can conquer the plenum, I will be able to install the Fastman throttle body, and my volant intake in the near future. I'm even thinking about perhaps linexing my own bed, not sure yet though. Anyways, that's my plan, and I appreciate the support from you, and many others...
Now the wait continues for my truck. I have a feeling they had to open that transmission back up and fix something. It's been 3 days and no phone call. I'm actually glad, because I know they are at least doing something about it instead of blaming it on my engine.
