ROYAL PURPLE!!
Old Feb 26, 2008 | 09:44 AM
wayneo360's Avatar
wayneo360
Default ROYAL PURPLE!!
hey guys
i picked up 4 quarts of royal purple engine oil yesturday and 1 can of restore. im going to do the oil change in shop class in like 2 hours. ive read good things about both the royal purple and the restore so im hopeing to feel a little difference in just how my engine runs. has anybody else used royal purple? im also going to do a compression test either tomorrow or thursday to see if my compression was in spec after the restore, dont have enough time to do a compression test before i dont think so im just checking just to check.. ill let you guys know how i like it later in the week.. talk to you guys later, peace
Old Feb 26, 2008 | 09:47 AM
Kohburn's Avatar
Kohburn
Default RE: ROYAL PURPLE!!
i've used royal purple - loved that stuff. noticed minor improvement in milage, lower rpm on highway in OD, etc.
Old Feb 26, 2008 | 09:52 AM
wayneo360's Avatar
wayneo360
sweet man yea im hoping to gain a little milage.. and i am giong to do a compression test before so ill let everyone know the before and after numbers
Old Feb 26, 2008 | 10:33 AM
pcfixerpro's Avatar
pcfixerpro
I wouldn't waste my money on royal purple if your going to put in restore. I was plannin on running cheap conventional oil with the restore, then switch back to synthetic.
Old Feb 26, 2008 | 11:27 AM
hometheaterman's Avatar
hometheaterman
I've been running Royal Purple in all my vehicles for a while now. It's expensive but I like it.
What motor do you have? Are you sure it only takes 4 quarts? Mine takes closer to 5.
Old Feb 26, 2008 | 12:40 PM
dusty_duster's Avatar
dusty_duster
I just changed the oil in my '01 Ram. I used to use dino oil, but I decided to try full-synthetic Quaker State oil. (They make a kind specifically designed for high-torque applications like towing.) I can't believe the difference. I get easier starts, better mileage, and more power.
I use Royal Purple in my Duster, and it works really well.
Old Feb 26, 2008 | 12:49 PM
98DodgeRam1500's Avatar
98DodgeRam1500
ORIGINAL: Kohburn
How would it lower your rpms when your TC should be locked up...?
Old Feb 26, 2008 | 12:51 PM
Jr. Mechanic's Avatar
Jr. Mechanic
Amsoil is better than RP, RP is a class IV oil while amsoil is a class V
Old Feb 26, 2008 | 12:58 PM
1BigRamaniac's Avatar
1BigRamaniac
No one ever says I get x mpg over regular oil. Am I the only one who keeps a fuel log? I have gone nearly 200k on Quaker State, or the Quaker State high mileage, Fram filters, changed about every 5-7k miles. Synthetic would pay for itself during the life of the oil(it goes 12-15 right?)if it could return 1mpg, but not one person seems to have actual proof of that.
The first time you go RP you have to change it at 4000, then you can go 12,000. That is expensive.
Old Feb 26, 2008 | 01:11 PM
98DodgeRam1500
ORIGINAL: 1BigRamaniac
and I am sure in that 12K theymight have to add a QT.
how much is this per/qt? I see it online for around $6-7 p/QT
