Calipers
RE: Calipers
Silver
Spending
Try replacing front rotors with slotted or drilled rotors 160.00 Top of the Line Pads $50 - $60. Upgrade rear Drums with the bigger cylinder trick. $45.00 maybe.
While you got it all apart Paint the calipers (silver would be my choice on your truck.) Paint rear drums (black or silver) One thing about painting Drums. Use a little grease or vasoline at the contact points. (lug holes, center axle hole, back of the tire rim.) It will keep the paint from gluing the tire to the rim, etc.
Magic, one weekend, Couple hundred bucks, sincere upgrade to your brakes, & they will look better to. 1/2 or less the price of just the preformance front calipers.
The pic is from my Little Ride.
Jeff
Just an old guy with Hi temp paint
Spending
Jeff
RE: Calipers
ORIGINAL: Silver_Dodge
Is there a caliper upgrade for our trucks? I haven't seen any aftermarket calipers that were any better then stock. Anyone running anything beefy?
http://www.pavementsucks.com/showcase/bigcaliper.php
Trending Topics
RE: Calipers
https://dodgeforum.com/m_1025264/tm.htm
Try that, thats a lot cheaper. if you do something let me know how it works, my Ram stops hard too.
