My Custom Bracket for the Edlebrock Air Hat
Old 04-17-2008 | 10:45 AM
hometheaterman's Avatar
hometheaterman
Default RE: My Custom Bracket for the Edlebrock Air Hat
ORIGINAL: Obiejuankinobie
Hometheatherman, thats a Grade 8 hex bolt you have holding your bracket on. You can probably lift your truck up from your air cleaner...hehe
Seriously sweet setup. I plan on doing the same as soon as I find a job. Imports from Taiwan put our Screw and Bolt company out of business.
I think I just used what I had laying around the house if I remember correctly. I might have gone to the store to get it but I think I just used what I had at the house.
Old 04-17-2008 | 10:50 AM
hometheaterman
I found this is a thread on PS showing how to bend it. I'm pretty sure this is the bracket that comes with this air cleaner assembly and it seems to block the butterflies slightly too. I think it's just how this setup is.
Old 04-17-2008 | 12:37 PM
Cereal Killer's Avatar
Cereal Killer
You could grind away a good bit of what's blocking the butterflies
Old 04-19-2008 | 01:21 AM
Bruce RnC's Avatar
Bruce RnC
That bracket ain't bending for nothing. For the small amount that the bracket blocks, it probably doesn't mean a whole lot. As for the set screw mounting, it's been on almost a month & has not loosened a bit.
Old 04-20-2008 | 08:53 AM
charlie1935's Avatar
charlie1935
ORIGINAL: zddp8868
the edelbrock product is an air cleaner, not an AIR HAT.
http://www.chevyhiperformance.com/te.../photo_01.html
see that device on top of the carburetor on that engine? THAT is an air hat. it measures the velocity of the air moving into the engine.
Looks like a velocity stack to me.
Quick Reply: My Custom Bracket for the Edlebrock Air Hat
