Trans is coming out tomorrow!
Just like the title says... Anyone have any secrets that make this easier or anything. I have lots of tools so that wont be a problem. I hope it comes out just like any other trans with no surprises or i will be pissed to say the least. Saving around $500 by taking it out and putting it back in myself.
Also, are there any bolts that can not be reused? I figure the Torque converter...but other than that?
Thanks guys! Wish me luck!
Take pictures for selfknowledge , plastic baggies lable the bolts .. really its not hard to drop the trans , lable all your connectors like put 1 with 1 , 2 with 2 , this a 2 wheel drive ? or a 4x4 ? have a trans jack or just using a jack ? the trans dip stick tube just pulls out of the trans , that has to come off , easier to take the 4 bolts off the crossmember ,then take the 2 bolts off the trans .. once you drop the trans use a block of wood and jack up the rear motor so its not just hanging there..
Usa a trans Jack or rent one. Dont mess with a jack. I was lucky and got to use a lift at school. The Cross member is really fun to get out. Use to large crow bars. Flush your cooler lines. Dont crush your Crankshaft positioning sensor or wiring. Make sure you seat that torque converter all the way in the tranny.
ORIGINAL: jagxtype
Thanks for the reminder of the dipstick tube. Also, what can i use to flush my lines out? That was the downfall of the trans to begin with.
the check valve had long been removed. The whole trans was flushed and the buildup of junk stopped up the filter which led to failure. Had enough crud in it to stop it up twice. I need to get them really clean somehow without spending a lot of money. Anyone have any suggestions?
Trending Topics
New and call it cheap insurance that's exactly what I would do. Nothing like losing a $1500 Tranny to a $100 cooler and lines.
well with recent events i havnt felt much like working on the truck but i started yesterday. So far i have all the electronics out, the motor-mount to bellhousing brackets, the driveshaft, drained the fluid in the pan, took loose the linkage. Now i just need to take out the bellhousing bolts, the starter, and the torque converter/flexplate bolts., and take off the cooling lines. After that i should be able to loosen the crossmember and yank that thing outta there. Or atleast i really hope so. Any pointers on the pain in the *** bellhousing bolts other that a long extension with a swivel???
Like someone said earlier, make sure you don't crush the lines going to the crank sensor, believe me it will lead to alot of problems, I did that in my jeep and needless to say 1000 dollars later, I gave up trying to fix it, took it too a shop and its been there almost a month.
