have posted this before with no results, so i will try again! have a 99 dodge 150, 5.2 magnum v-8, automatic, 2wd that has a serious problem. today i had to drag it home because it wouldnt start. wouldnt do anything but click. cleaned cables, but same. after i got it home, it started right up, but starter stayed engaged(could turn key off, and starter was still spinning with key off untill i unhooked battery cable) hooked cable back up, and turned key, and it started again. turn key off, and starter still spinning. changed relays, and same thing. has a new starter that has never given any problem till now. starter was replaced due to the same thing happening a year ago, now right back to the starting line. any ideas???
