98 2500 lift question
Old Jun 25, 2008 | 09:28 AM
sunngod's Avatar
sunngod
Junior Member
Default 98 2500 lift question
I just picked up a 98 2500 regular cab a few days ago. It is rolling on 315/75 R 16s (roughly 35s) on the stock 16 x 6.5 wheels [sm=WTFsgign.gif]. In any case the tires are shot and I am getting ready to replace them. The problem is I don't want to put the tires that are twice as wide as the wheels, but I don't know what size to go with. The truck appears to have a lift. The blocks in the rear measure about 6 inches. I am not sure how much lift there is. I don't think there is 6 inches of lift on the truck because the shocks look stock (stretched out, but look stock), the upper and lower arms are stock, and there are no coil spacers. The truck sits level so I am thinking that someone put new coils up front, but how much lift do I really have? Did these trucks have blocks on the rear from the factory?
Old Jun 25, 2008 | 09:33 AM
hometheaterman's Avatar
hometheaterman
Default RE: 98 2500 lift question
I'm not so sure that isn't stock. Don't the 2500's have a huge block like that from the factory?
Old Jun 25, 2008 | 09:57 AM
zman17's Avatar
zman17
Retired Moderator - RIP
That is stock, and it doesnt look like the truck is level. The picture looks like its parked on an incline. I know pistures are decieving but my 1500 has blocks that look like those.
Old Jun 25, 2008 | 11:00 AM
sunngod's Avatar
sunngod
Junior Member
It sits very level, but the picture was taken by a lousy photographer.
So these trucks came from the factory with blocks? That is scary. I have seen bad thing happen with block, but I guess dodgegot them right. I am amazed that you could fit a315 75 16 on these trucks stock. If I go back with the same size I will get new wheels because that tire is way too wide for that wheel.
Old Jun 25, 2008 | 11:05 AM
hometheaterman
I wouldn't be surprised if you could fit 315's on a stock 2500 with minor issues as long as it was the stock wheel. Aftermarket wheels may be worse.
BTW yes the Dodge's do come from the factory with blocks. Blocks don't seem to be that bad by themselves. Usually when I hear of problems it's when people stack blocks which is a huge no no.
Old Jun 25, 2008 | 11:28 AM
Silver_Dodge's Avatar
Silver_Dodge
Does it have a body lift?
Old Jun 25, 2008 | 03:45 PM
sunngod's Avatar
sunngod
Junior Member
no body lift. It is also 4wd.
Old Jun 25, 2008 | 04:09 PM
THEGOLDPRO's Avatar
THEGOLDPRO
thats stock, both my 2500s have the same block and sit just as high.
Old Jun 25, 2008 | 08:32 PM
mstephen89's Avatar
mstephen89
If you want to change the wheels, you are going to have to lift the truck, or go down to 305's.
Old Jun 26, 2008 | 10:02 AM
ct.russ's Avatar
ct.russ
the 2500 sits exactly 3 inchs taller than the 1500 in the front ..i was torn between going 2500 springs or a leveling kit .. i went with the kit .. im not sure with the blocks out back ..im thinking mine has 4 inch blocks from the factory then the kit gave me another 1.5 block (ya i know stacked its best gonna redo it with an add a leaf ) for a total of 5.5 inch block .. you said yours is about 6 inch and it sits level .. longwindedly id say yours is stock ... hope this helped .. russ
