Changing wiper switch
Old Jun 26, 2008 | 09:53 AM
kowboydmac's Avatar
kowboydmac
Default Changing wiper switch
I couldn't figure out how to get the two plastic pieces off the steering column, and couldn't find anything but how to fix intermittent wiper fuses and such when i searched.
I know there's a star bolt on the bottom, but the two pieces shrouding the column I can't seem to get off. Is it just a trick manuever to get off?
Old Jun 26, 2008 | 11:48 AM
zman17's Avatar
zman17
Retired Moderator - RIP
Default RE: Changing wiper switch
IIRC there is more than 1 screw on the bottom shroud. And the ones holding the switch to the column are tamper proof torx .
Old Jun 26, 2008 | 01:24 PM
zman17's Avatar
zman17
There is 3 screws holding the bottom shroud! There is 1 screw in the middle that you can plainly see, which is the one you are talking about. But if you look to the left and right you will see 2 holes that have a screw in each one.
Old Jun 26, 2008 | 02:59 PM
kowboydmac's Avatar
kowboydmac
I see the holes but i can't tell what type they are. I stuck a screw driver up there but it didnt do anything. lemme try the star.
what the eff? are they riveted? lol. there's no head for mine, unless it's a type I haven't used before.
Old Jun 26, 2008 | 03:01 PM
BadStratRT's Avatar
BadStratRT
The Forum Tyrant
i believe that its a phillips head...ill check right now and let you know in a second. once you get that shroud off, youll need a raised-center torx to remove the switch itself. what isnt working, the wipers or something with the lights?
Old Jun 26, 2008 | 03:04 PM
BadStratRT's Avatar
BadStratRT
The Forum Tyrant
yes, they are phillips head...
Old Jun 26, 2008 | 03:07 PM
zman17's Avatar
zman17
They are the same size as the one in the middle . #20 torx
Old Jun 26, 2008 | 03:08 PM
kowboydmac's Avatar
kowboydmac
Man, I stuck a philips in there and it didnt catch on anything. I'll try it again.
Anyway, I just got a crapped out switch. It doesn't lock in the off position, so when I flip the blinkers to turn left or right, 9 times out of 10, when it kicks back into place, it'll turn the windshield wipers on and I have to play with it to put it in it's "g spot" to turn off. Oh, and when you depress the button to squirt your windshield wiper fluid, it's been jammed so that sensor part continually stays on. I had to disconnect the motor pump because of it.
Old Jun 26, 2008 | 03:10 PM
kowboydmac's Avatar
kowboydmac
Ok, guys, I'm weirded out now lol. Whatever screw that's in there, on both sides apparently, has no indentation as to what will unscrew it. Philips doesn't work and I can't get a star down in there, but when I looked in it with a flashlight, it had no indents on it.
Old Jun 26, 2008 | 03:26 PM
BadStratRT's Avatar
BadStratRT
The Forum Tyrant
thats odd...im not sure what to tell you about the screws. maybe yours is different than ours.
for that switch, theyre pretty expensive, but pghsebring bought a new sebring a few weeks back, and the wiper switch was bad..i took it apart and it was pretty simple to fix...
