Mopar Airhat
Old Jul 26, 2008 | 01:41 PM
  #21
94Ramsey's Avatar
94Ramsey
Default RE: Mopar Airhat
someone should do a dyno vid of befor and after. "im looseing power, it dosent work, i get crappy mpg" wtf do you expect. what you gain in HP you loose in mpg. i've knowticed no loose in anything. more a gain. so what if you loose 2mpg. these trucks arent race cars.
Old Jul 26, 2008 | 02:02 PM
  #22
Viper37's Avatar
Viper37
ORIGINAL: Cereal Killer
You probably shouldn't recaliberate your "computer" then. I didn't and I didn't notice any loss in torque. I seriously don't see you losing low end by allowing a little bit more air to get into your engine. I didn't lose any gas mileage either. I think you screwed up your PCM.
How did I screw up the Computer?
Without resetting it, How is the Computer supposed to know the difference then? The first time I took it out without clearing the Computer's ram, at WOT it would shift 400 rpm's too soon. This was quickly alleviated by Disconnecting the battery for a few min, thus clearing the ram.
I seriously dont see why I would lie about this, so many times. Think about it.
ORIGINAL: 94Ramsey
You are "loosing" power? Good God, how did you get out of Elementry school?
Old Jul 26, 2008 | 03:19 PM
  #23
xskylinedx's Avatar
xskylinedx
I switched from the k&n fipk to the mopar air hat and felt a shift from mid/hi to low/mid.
viper; who gives a s**t about spelling, come on man.
Old Jul 26, 2008 | 04:59 PM
  #24
zman17's Avatar
zman17
Retired Moderator - RIP
I agree! Everyone should take a f>ing chill pill with the spelling!!!!!
Old Jul 26, 2008 | 05:01 PM
  #25
zman17's Avatar
zman17
You have to type so fast with the forum probs it's ridiculous! I hope I spelled everything right!
Old Jul 26, 2008 | 05:03 PM
  #26
zman17's Avatar
zman17
And BTW! I just took off the 14X3 AC and put the stock hat back on and gained all kinds of low end!
Old Jul 26, 2008 | 05:43 PM
  #27
aim4squirrels's Avatar
aim4squirrels
When you reset the PCM, it starts out running on the rich side, which will kill MPG and give you more power.
Old Jul 26, 2008 | 05:45 PM
  #28
aim4squirrels
I have noticed this every time I reset the PCM regardless of what air cleaner I run.
Old Jul 26, 2008 | 05:47 PM
  #29
aim4squirrels
I would imagine that if you went from the Mopar airhat to the stock airhat without a reset, the same thing would happen as the parameters of the PCM are still learned from a higher flow air cleaner and stuffing it up with the old airhat is basically causing it to run rich again.
Old Jul 26, 2008 | 05:48 PM
  #30
aim4squirrels
It should then lean itself out to a new lower flow of air and increase MPG. Regardless, I believe it takes my truck about 200 miles or so to relearn a PCM reset. I notice worse mileage until that point.
