programmer and crank
Old Aug 1, 2008 | 11:33 PM
lastrights's Avatar
lastrights
Default programmer and crank
i have 2000 ram, so that means it has the death flash.so dodge reduced the timing by 4 i think. but anyways say i do the crank sensor mod to put it back to stock. then after can i use superchips programmer for performance? or is that too much timing
Old Aug 1, 2008 | 11:35 PM
lastrights's Avatar
lastrights
Default RE: programmer and crank
bbecause a stock 360 motor with no death flash ,and using a programmer would come out too be the same thing right ?
Old Aug 2, 2008 | 12:33 AM
jasonw's Avatar
jasonw
Site Moderator
death flash + programmer = performance
stock + programmer = performance
Yep, they'll both be the same in the end if you leave the crank sensor alone.
Old Aug 2, 2008 | 07:53 AM
lastrights's Avatar
lastrights
but what if i do the crank sensor and prgrammer, becasue the programmer prob only lets you do so much timing.
deathflash -4 sencor mod +4 = stock. then programmer puts me +4
stock motor 0 then programmer = +4
Old Aug 3, 2008 | 11:27 AM
lastrights's Avatar
lastrights
anyone ????
Old Aug 3, 2008 | 01:43 PM
aim4squirrels's Avatar
aim4squirrels
the superchip[s programmer is a new flash, not an addition to a bad flash. it will overwrite the pulled timing and add whatever they've done, which is why people who were death flashed think their truck is so amazing after getting a programmer.
dillonjm's Avatar
dillonjm
Sorry, tried posting yesterday and it wouldn't let me.
You can do the crank mod and a programmer at the same time. I'm not sure if it helps or hurts any, butI never re-adjusted my sensor back to the stock positionafter I bought my programmer.Itdoesn't ping any with the 87 setting on my HPP3 and 89 octane gas (5% ethanol mix). Hope this helps.
Old Aug 4, 2008 | 07:14 AM
lastrights's Avatar
lastrights
you think its ok to get the new superchips that is being avertised the flashpaq or is there a better brand of superchips??i
Old Aug 4, 2008 | 07:16 AM
lastrights's Avatar
lastrights
is there a better superchips(older version) maybe, i cant afford sct tuner or b&g flash
Old Aug 4, 2008 | 08:51 AM
aim4squirrels
I would imagine the newest tuner would be the best, the old superchips was a decent tuner. If you can afford the superchips, you can afford the B&G flash and it is (or should be) a superior tune.
