projector lights
Old Oct 8, 2008 | 09:04 PM
  #71
aim4squirrels's Avatar
aim4squirrels
I did change the 9005 bulbs. They have illuminated in the past, just not fully so I know they aren't blown.
Old Oct 8, 2008 | 09:35 PM
  #72
lastrights's Avatar
lastrights
when i did projecttion headlights in my buddies 98 we had to do re wiring to the halos and evreything to get it to work right, but it was night and day diffrence when we did it right
Old Oct 8, 2008 | 10:42 PM
  #73
aim4squirrels
I have run grounds from both the high's and low's to the frame at this point. All I end up doing is completing a constant on circuit and the lights work without a switch. What am I missing here??
Old Oct 14, 2008 | 10:53 AM
  #74
tresvatos's Avatar
tresvatos
Bump. Anyone have any ideas on doing the ebay projector shield mod? Thanks
Old Oct 14, 2008 | 01:12 PM
  #75
Viper37's Avatar
Viper37
Yeah, don't.
Just get the Clear euro headlights from LMC and throw Bi-Xenon projectors in them.
Old Oct 15, 2008 | 07:34 PM
  #76
aim4squirrels
FIXED!
The Blue and Black wires on the PnP harness were reversed, shipped that way from the factory. I popped them out with a very small screwdriver and switched them. Look WAY better and work right too. Have to aim them tonight. Kinda pissed that I hacked up the harness, but it's fixed now.
Old May 16, 2010 | 10:47 PM
  #77
Gav1n8's Avatar
Gav1n8
I know this is a old thread but I wanted to fix some confusion... The Halo Headlights you ordered come pre wired for the Sport Dodge Ram Models. Therefor it is different if you don't have the sport and thus have to change the two wires like stated above. You didn't have to pop them out, you just have to cut and splice. Sorry I didn't see this post when it was still alive. Hope this helps...
If you decide to search this topic you will see that a long time ago this was covered....
Old Nov 2, 2013 | 10:52 PM
  #78
madisonff5020's Avatar
madisonff5020
Originally Posted by bizlebee
PROBLEM SOLVE!!!! i was right
the ground wire that ran to the high beam on the plug and play wasn't grounding ( it was wired right just wasn't making a good connection ). so i cut the wire from the plug and play going to the high beam light and re attached the ground to the truck frame ( had to do it on both sides). the high beam light now gos off when i switch between highs and lows and the projector cut off and the high beam turns on. its daylight here now but i can already see a huge improvement it the brightness of the bulb/light output. aslo my fog light turn on now when i turn my lows on.problem solved! thanks for all the help.if anybody gets these and needs help setting them up i would be more then happy to run you through it.
PHOTOS OF THE PROJECTORS!
my handy work
http://i55.photobucket.com/albums/g1...e/IMG_1996.jpg
http://i55.photobucket.com/albums/g1...e/IMG_2002.jpg
halo and leds
http://i55.photobucket.com/albums/g1...e/IMG_1984.jpg
iris melting projectors
http://i55.photobucket.com/albums/g1...e/IMG_1979.jpg
daytime
http://i55.photobucket.com/albums/g1...e/IMG_1954.jpg
http://i55.photobucket.com/albums/g1...e/IMG_1956.jpg
http://i55.photobucket.com/albums/g1...e/IMG_1957.jpg
Can someone please help me... I am having the same problem...
