Need some help....Temp gauge not working
Old Nov 13, 2022 | 09:23 AM
Hollywood1978's Avatar
Hollywood1978
Default 99 dodge ram 2500 v10
Temp gauge doesn't move off of cold replace sensor,sensor plug,water pump nothing it moves if I put heat to the thermostat housing any ideas
Old Nov 13, 2022 | 09:39 AM
That's odd..... if warming the sensor makes it work, then, it *should* work.... it's a two wire sensor, so, not like it needs to ground to the block....
Old Nov 15, 2022 | 10:59 PM
96albertaram's Avatar
96albertaram
Originally Posted by dhvaughan
try the gauge/cluster self test. hold odometer trip meter button in and turn key to on. continue holding button in until odometer reads CHEK, and then release it. cluster will self test, turning all lights on, and then sweep all gauges to about 1/4, then 1/2, then full. see how your temp gauge acts.
Will this help reset mine aswell, mine is reading opposite actually hotter then what it is. Sorry not trying to highjack your post
Old Nov 16, 2022 | 07:29 AM
Nope, doesn't reset anything, just tests all gauges and bulbs.
Old Nov 16, 2022 | 09:18 AM
96albertaram
Thank you sir
