Dyno #'s 5.9 2wd
I just got my truck dynoed on a Mustang Dyno. HP 220/ Torque 318. Mods are on my Sig. list and the SCT tune was on performance. I was a little disappointed with the #'s at first, since I dynoed my truck last year on a Dyno Jet and the HP #'s were about the same. Mods were the same except I had a Hypertech last year instead of the SCT programmer. I thought the #'s would be a little higher since my truck feels a lot stronger with the SCT tune. I felt a lot better after the tech told me that the Mustang Dyno produces more accurate and realistic behind the wheel HP and Torque #'s, than the Dyno Jet because the Mustang Dyno is a load dyno. Since the Dyno Jet is not a load dyno, it may produce higher HP and Torque #'s which might not give true behind the wheel HP & Torque #'s. On the flipside, I was pleased with the torque #'s. Hopefully, I can scan the dyno sheet and post it soon.
Yeah, the companies all do it, as far as I'm aware. I doubt they really exaggerate the crank HP numbers much if at all, using the crank #s instead of the at the wheels is "exaggeration" enough.
On a side note, the 50mm Fastman might be holding him back slightly, as a 52mm is what is recommended for the 5.9L. But I doubt it would have made a hardly any difference at all in total HP/TQ numbers.
Trending Topics
