Old Aug 13, 2015, 08:35 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Lighting Guides
Print Wikipost
Just got cab lights.. no idea how to install
Old Dec 31, 2008 | 05:40 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Maybe reading the directions that came with the lites will help!
Old Dec 31, 2008 | 07:59 PM
vmann's Avatar
vmann
were no directions. And there is only wire that is connected to the light.. the black one
Old Dec 31, 2008 | 08:31 PM
dodgeram07's Avatar
dodgeram07
Originally Posted by dodgeram07
black is power(werid) and the srew that goes in the roof is the ground... tyr gounding the srew and power on the black and see if it works.
this help?
Old Dec 31, 2008 | 08:34 PM
Rex-TheDOGG's Avatar
Rex-TheDOGG
Originally Posted by vmann
i can drill and do all that fine. Its just the wiring. I tried to connect it to make sure the lights work and nothing. The switch lit up but the light did not. Im a little confused because there is only a black wire coming out from the lights which i am assuming is the grounder. I even tried connecting that black wire to the harness wire that came with it.. still nothing.
Dude, you are in way over your head. Find someone to install those for you. You'll thank me later.
Old Dec 31, 2008 | 09:54 PM
LegendKiller89's Avatar
LegendKiller89
wow.... lol
Old Jan 1, 2009 | 09:42 PM
vmann's Avatar
vmann
way in over my head... my ***.
I installed them today. They look good and ill get pics up tomorrow. One question though.. how do i wire my lights in with my headlights? i dont want to have to flip an extra switch to turn them on.
Old Jan 1, 2009 | 09:58 PM
mjackson92rs's Avatar
mjackson92rs
Connect the parking light 12v (+) wire to the power source for your lights. It's as easy as that. Did you use a relay for your lights?
Old Jan 1, 2009 | 10:51 PM
vmann's Avatar
vmann
i dont know where the parking light wire is and i did not use a relay. I ran a wire from my battery to my switch (with a fuse on the wire.. came with lights) and i also connected my lights directly to the switch. diagrams, pictures, links would be appriciated. thanks
Old Jan 1, 2009 | 11:25 PM
dodge15004x45.9's Avatar
dodge15004x45.9
watch you dont burn down yr truck i had a problem with my fog lights when i was trying to use dodges wiring and i was told that i was lucky that my truck did not burn down. and when u take yr turn single off the green wire is turn black is ground and i cant remember the color of the other wire but that one is the one you want to clip into and if im wrong some please correct me if im wrong.
Old Jan 2, 2009 | 12:26 AM
mjackson92rs
To use the running lights as a switch, you need to either look up the color of the wire or use a diagnostic tool such as a DMM or test light to determine the wire you need. You can then tap into that wire for power. This will replace the wire that you ran from your battery to your switch and will give power to your cab lights when the parking lights are turned on.
