Old Aug 13, 2015, 08:35 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Lighting Guides
Print Wikipost
Just got cab lights.. no idea how to install
Old Jan 2, 2009 | 03:03 PM
  #31
dodge15004x45.9's Avatar
dodge15004x45.9
i want to get these in smoked
http://4wheelonline.com/Products.asp...oductId=110725
but i think im going to have someone put the in for me.
  #32
Rex-TheDOGG's Avatar
Rex-TheDOGG
Originally Posted by vmann
And what yall are talking about is cutting part of the wire from the lights and attaching another wire to it and ground it somewhere else? In the diagram it shows g302 is right in the middle... if i run a wire right from the middle i would have to run a pretty long cable to ground off something other than the roof metal.
No. However, the ground harness I mentioned may be a forgone conclusion if you used sheetmetal screws on the lights instead of machine screws. If you used machine screws to attach the lights going through the cab roof, then you can easily make a ground harness to attach to the screws and ground at G302. See 8W-90-24.
Old Jan 2, 2009 | 03:34 PM
  #33
vmann's Avatar
vmann
im looking at 8w-90-24 and i still have no idea what you mean. I used sheetmetal screws and they are the grounders.
Old Jan 2, 2009 | 03:51 PM
  #34
vmann's Avatar
vmann
just pulled my headlight switch and i see a yellow wire with a thick black line and a yellow wire with a thin black line.. either one of those it? and im going to connect them with those things you put the wires in and clamp down.. that way i dont have to strip any harness wires.
Old Jan 2, 2009 | 04:09 PM
  #35
mjackson92rs's Avatar
mjackson92rs
That would be a wire tap. Use a test light or DMM to determine which wire is running lights. Guess and check isn't the best way to do things when working on electronics.
Old Jan 2, 2009 | 04:10 PM
  #36
Rex-TheDOGG
Nevermind. They're grounded well enough with the sheetmetal screws. BTW, the word is "grounds" not "grounders."
Old Jan 2, 2009 | 04:48 PM
  #37
vmann's Avatar
vmann
grounders is an amazing word. And its all done. I connected my lights to my parking lights and all that.. they come on when i flick my switch. Ill get pics up later. Earlier someone said that i need to go with a 20 fuse. i have a 15 in there right now. should i get a 20?
Old Jan 2, 2009 | 05:34 PM
  #38
Rex-TheDOGG
15A is correct. Did you wire it before or after the headlight switch? If you wired it into the parking light circuit, are you still using the rocker switch that came with the lights?
Old Jan 2, 2009 | 05:39 PM
  #39
zman17's Avatar
zman17
Retired Moderator - RIP
The yellow wire you are saying that has a thick black line, is actually a black wire with a thin yellow line, is that the one you taped in to? Because thats the one you want. And leave the 15amp fuse in there.
Old Jan 2, 2009 | 08:36 PM
  #40
mjackson92rs
how about some pics
