how much pulling?
Old Jan 18, 2009 | 08:37 PM
modracer's Avatar
modracer
Default how much pulling?
hey evryone
im looking at buying a trailer and i have found a 20' 5th wheel trailer with 2 2500lbs axels underneth it for cheep and i was woundering if my 1999 dodge ram 1500 with 318 2wd auto would be ok pulling it i wouldnt have any thing huge on it nothing more than i had on it with my 16' car trailer
thanks for any input
kyle.m
Old Jan 18, 2009 | 09:46 PM
iwhitne's Avatar
iwhitne
don't go up or down any hills.... and add some air bags or helper springs... brake controller...ect... do you know how much the trailer weight is empty?
Old Jan 18, 2009 | 09:57 PM
dodgeram07's Avatar
dodgeram07
turn off OD.. and add a trans cooler
Old Jan 18, 2009 | 10:10 PM
dodge15004x45.9's Avatar
dodge15004x45.9
yo yr nuts a 5th wheel in a 1500 318 not event a 360 i woulnt do it! get ready for many trans rebuding i would get an account down at yr local trans shop. yr nuts!
Old Jan 18, 2009 | 11:01 PM
txredneckmedic's Avatar
txredneckmedic
its weird...but i agree with dodge....i wouldnt tow a 5th wheel with a 1500
Old Jan 19, 2009 | 01:26 AM
modracer's Avatar
modracer
whats the big difrence between my 16' ball reciver trailer witch i use to move a bunch of stuff around the farm with compared to a 5th wheel if anything id think its better cause its putting the load over the axel.
and i already have a tranny cooler and break controler for my 16' car trailer and its pulled some mighty loads and this is just tempary till i get my cummins
Old Jan 19, 2009 | 01:59 AM
dodge15004x45.9
yea there better cause of load placement u said the new trailer was 20' ft yr old one is 16'ft thats alot more trailer weight with out any load on it. what the weight of the 5th wheel yr going to be putting in the bed of yr truck. are 1500 are like everyday driving not heavy hauling! buy a 3500 cummins. also yr truck needs to be able to hande the weight of the trailer loaded. i got a buddy w a 16x6.5 that thing holds 7,000 or 10,000 that is alot on his 2500 5.9 gas and its not a 5th wheel and hes has a break controler and hes turns that sob up.
Old Jan 19, 2009 | 10:02 AM
iwhitne's Avatar
iwhitne
like I said earlier... how heavy is the trailer empty?
Old Jan 19, 2009 | 10:41 AM
padodgeram's Avatar
padodgeram
Originally Posted by modracer
hey evryone
kyle.m
as long as you are under the Gross weight you will be fine.. If your gonna tow alot or heavy get a trans cooler ...
Old Jan 19, 2009 | 12:56 PM
dillonjm's Avatar
dillonjm
There is no reason you can't pull a 5th wheel trailer with a 1500 as long as you stay under the gross combined vehicle weight rating.
With 2 2500lb axles under it you're not going to be towing much. Are you sure thats all the axles are rated for (those are some pretty weak axles for a 5th wheel trailer)?
