"1999" Dodge Ram 1500, upgrading to compass and sensor harness from 1997 Dodge Ram
Help,
Where is the harness under the dash that carries the sensor wires in a 1999 Dodge Ram 1500, (VT/LG & BK/LB), these are the wire colors.
I can see a very large plug with a 10mm nut and another plug with a hinge locking device,
nearby...That's as far as I have looked and haven't seen these wires as of yet.
BTW, I'm getting older by the years.
I will scan the manual pages and e-mail them to you tomorrow 2/8.
Im having an issue finding the wiring diagram for my 98 ram sport i had the same consule in the thred but splicing in a connector for an 01 over head console. Would you be able to send that diagram so I could make sense of the connector so I know where to pin in my new one? Thanks! Consule out an 01 Connector from 01 consule Connector from cab to 01 consule Consule from 98 Connector from cab in the 98 Conector from 98 consule
