best 46rh shift kit
Old Feb 7, 2009 | 12:32 AM
  #21
dakotas ram's Avatar
dakotas ram
should i replace my separator plate too?, is it easy?....i guess ill be goin with the jr.......will i be able to tell a noticeable difference?
Old Feb 7, 2009 | 01:21 PM
  #22
99blueram's Avatar
99blueram
Dakotas, i put a Jr kit in my 1999 46re and i like what i does. There is know big jerk just a firm shift feel. Also rebuilt trans myself with no issues. Also running Amsoil fluid for 2500 miles now and no issues. Only issue with mine was bad front bad, all else looked great for 93000 miles. Just thought i would share a little bit for what it is worth..Good Luck!!!
Old Feb 7, 2009 | 01:27 PM
  #23
99blueram's Avatar
99blueram
MonteC, That person should be banned from the rebuil world. This is most of the reason i will try to tackle my own work because of the issues that some people take on others. I am so glad that everyone that reads this forum can get honest answers to what they need. Keep up the good foe all of us. Just want to say Tanks to everyone because i got alot of my answers from this reading. Thank You Again!!!!
Old Feb 11, 2009 | 10:20 PM
  #24
transguy37's Avatar
transguy37
You don't have to replace the seperater plate, A new Transgo plate is a stock plate, you have to drill your own holes. Only replace if damaged by check *****.
Old Feb 12, 2009 | 01:06 AM
  #25
dakotas ram
will the sk tfod http://www.transgo.com/sk_dodge.php fit my truck? it says diesel but under the application it says gas and diesel.........
and this site says just diesel
http://www.700r4l60e.com/store/produ...0&bestseller=Y
Old Feb 12, 2009 | 08:29 PM
  #26
transguy37's Avatar
transguy37
Diesel has different spring tensions than a gas. If says diesel and gas, they may have both spring opptions in the kit. If that's the case it will work.
Old Feb 13, 2009 | 12:35 AM
  #27
dakotas ram
alright....i think im gonna give em a call tomorrow to be sure....should i adjust my bands when i do this also?
Old Feb 13, 2009 | 08:00 AM
  #28
transguy37's Avatar
transguy37
It wouldn't hurt to go ahead adjust them while you are already there.
Old Feb 20, 2009 | 01:14 PM
  #29
dakotas ram
alright, got my kit in today....i just went with the tfod-jr.........it looks a little confusing.....when its talking about my lockup, is it my tc lockup? its got the option of slightly firmer or much firmer? also, its got the option to drill a hole in a shaft for increased OD lube.......is that pretty in depth to take that out?
Old Feb 20, 2009 | 11:02 PM
  #30
transguy37's Avatar
transguy37
Yep, you have a lockup tc, you can make it firmer if you would like, I just wouldn't go to firm. Drilling the hole in the shaft, I think that's talking about if you had the trans apart and drilling the intermediate shaft, I wouldn't worry with that one. Just what ever deals with the valve body.
