Engine oil
Old Feb 3, 2009 | 11:25 PM
  #21
95MaroonMonster's Avatar
95MaroonMonster
lol
synthetic oil can cause a leak if there was a previous leak that was plugged by particles in the dino oil, that are removed by detergents in the synthetic
Old Feb 3, 2009 | 11:29 PM
  #22
Laramie1997's Avatar
Laramie1997
Yea I knew that I just didnt feel like going in depth
Old Feb 4, 2009 | 12:16 AM
  #23
PurplDodge's Avatar
PurplDodge
Originally Posted by Laramie1997
BTW I think the only reason purpldodge uses RP is because of the color
That is only half of the reason!! I run it because it lasts longer than other synthtics. Oh and because its purple. If I spilled some on the truck I would'nt be able to tell.
I bleed PURPL!!!
Old Feb 4, 2009 | 12:20 AM
  #24
Laramie1997
Purpl, you prove my point. lol
Old Feb 4, 2009 | 12:39 AM
  #25
PurplDodge's Avatar
PurplDodge
Oh yeah, its purple.
Old Feb 4, 2009 | 01:53 AM
  #26
madmax0r's Avatar
madmax0r
YOur truck is Purple?
Old Feb 4, 2009 | 09:05 AM
  #27
charlie1935's Avatar
charlie1935
Originally Posted by 360dodgeram360
i use valvoline 5w-30 and a quart of marvel mystery oil right now. and Jason is right, thicker oil in the summer and thinner in the winter generally. in the summer the oil temp is hotter causing the oil to thin out. in the winter the oil doesn't heat up as much and stays thicker and doesn't circulate as readily. i.e. if you have 20w50 oil and it gets real cold you will have to change your oil just to start your truck.
I've used 20w50 in my 87 since it was new. Started up just fine as low as -10. At 170,000 miles and no engine problems.
Old Feb 4, 2009 | 09:30 AM
  #28
Gary-L's Avatar
Gary-L
Veteran: Navy
They use it because its syntheitic, I used to run Valvoline 10w-40 then switched to Rotella 15w-40, since its a little cheaper. I have thought about going to synthetic, but from what I have heard, if you have run a dino oil for a long time the syn oil will leak.
That is a persistent old wives' tale that won't die. You can switch to Synthetic today and it won't leak.
Old Feb 4, 2009 | 09:42 AM
  #29
shawngrace5's Avatar
shawngrace5
AMSOIL 10w-30, with an AMSOIL Absolute Efficiency filter, only way to go man, good for 8,000 Miles, or they have oil that extends service life to 1 year, 25,000 Miles.
GOOD ****!!! I run their racing oil in my 700hp late model and doubled my oil change life from Mobil 1 (SUCKS)
Old Feb 4, 2009 | 09:45 AM
  #30
Gary-L's Avatar
Gary-L
Veteran: Navy
Here's a link to a study of oil filters:
http://minimopar.knizefamily.net/oilfilterstudy.html
And the actual comparison itself:
http://minimopar.knizefamily.net/oilfilters/index.html
Fram is nothing more that overpriced junk.
