Bigger Oil filter for the 360/318 -Cheap-
Old May 6, 2009 | 07:33 PM
  #101
95MaroonMonster's Avatar
95MaroonMonster
very true, but a common rail has a higher towing capacity, so they say
id like a P-Pump 12 Valve, with twin turbos, water/methanol injection and a huge fuel plate, and a 5 inch straight pipe coming out in front of the rear tire...
...but by the time i get a newer rig, ill be able to afford a common rail, and by then all the 12 valves would be getting quite old
Old May 6, 2009 | 08:31 PM
  #102
PurplDodge's Avatar
PurplDodge
I'd like to get a 24-Valve or a Common rail for my dad when I buy Purpl. That way I can drive Purpl and the S-10, and he can take the Cummins to work.
Old May 6, 2009 | 08:47 PM
  #103
MAJohns's Avatar
MAJohns
on these oil filters size is not all that matters.... if you an find a smaller filter with higher microns you are doing just as good.... for example take a 5in. long filter with 10 micron and a 2in long filter with 30 micron i would say the 2in. filter is better.... so take all your filter stock and long ones and compare microns and see which one is realy better.... is longer always better?
Old May 6, 2009 | 08:56 PM
  #104
PurplDodge's Avatar
PurplDodge
The WIX 51085 filter(stock size) has a nominal micron rating of 20.
The WIX 51515 filter has a nominal micron rating of 19.
Old May 6, 2009 | 09:00 PM
  #105
MAJohns's Avatar
MAJohns
so the stock is actualy a little better on the filtration side?
Old May 6, 2009 | 09:01 PM
  #106
BigRedRam95's Avatar
BigRedRam95
so I am going to change my oil this weekend so should I use the stock size or get the ford one. Also I am going to get a relocater kit and put it on the next time I change oil so should I get the wix or stick the stock or ford filters. Thanks
Old May 6, 2009 | 09:06 PM
  #107
PurplDodge's Avatar
PurplDodge
Get a WIX 51515 filter.
Old May 6, 2009 | 09:07 PM
  #108
PurplDodge's Avatar
PurplDodge
I thought the smaller micron rating, the better?
Old May 6, 2009 | 10:02 PM
  #109
mopar1973man's Avatar
mopar1973man
Originally Posted by 95MaroonMonster
how much did that TP roll filter system cost, id like to get on for my next truck [common rail]
I got luck and got mine for nearly free... Being I had a orignal first gen FrantZ filter to bring to her in person puls I was helping for advertisement on another site...
But here is the price list for it...
http://www.wefilterit.com/orders/100/index.htm
But there cover oil (gas or diesel), fuel (gas or diesel), transmission, etc...
Old May 7, 2009 | 12:30 AM
  #110
KY2500's Avatar
KY2500
I would think any quality oil filter would perform nearly equal. I think the most important thing is keeping the air filter clean so do don't contaminate the oil. Most oil analysis i've seen point to the air filter playing a bigger role in contamination.
