Bigger Oil filter for the 360/318 -Cheap-
Old Dec 28, 2009 | 08:37 PM
  #171
PurplDodge's Avatar
PurplDodge
Originally Posted by wjxavier
seeing how this thread goes back 17 pages, and i really don't feel like going all the way back and reading it, would someone please explain what the benefits are of having a larger oil filter?
If you need the cross refrence for the bigger filter, they are buired in this thread, but I have them in my Oil Change DIY in my signature.
Old Dec 29, 2009 | 04:55 PM
  #172
wjxavier's Avatar
wjxavier
thats just it though, has anyone actually done any true studies or testing on this subject? i mean, in theory, it should be able to collect and hold more "dirt" but does it really justify buying a bigger filter? to me the normal sized one works just fine and i see no true benefits in buying a bigger one unless an actual test was done to determine just how much more dirt or how much longer the filter would last vs. a conventional one.
Old Dec 29, 2009 | 05:34 PM
  #173
Trey318's Avatar
Trey318
Its cheap and good quality.
Old Dec 29, 2009 | 11:39 PM
  #174
PurplDodge's Avatar
PurplDodge
That is just common mechanical knowledge. Ask any mechanic or anyone who knows a damn about filters, and they will tell you that a bigger one has the capacity to hold more dirt. It just makes sense. These bigger filters cost the same as a smaller filter, so why not?
Old Dec 30, 2009 | 09:43 AM
  #175
wjxavier's Avatar
wjxavier
ah gotcha...wasn't aware they cost the same.
Old Dec 30, 2009 | 10:17 AM
  #176
halfamil's Avatar
halfamil
It doesen't matter what kind of filter you use if you don't let your oil get old and dirty.
Old Jan 23, 2011 | 07:53 PM
  #177
madmax0r's Avatar
madmax0r
also don't forget it lets you add more oil... more oil means that it is cycled less often and used less often aka should last longer.
i'm sure this is not a significant advantage but whatever
oh one more thing, the bigger surface area should make it easier for your oil pump to do its job
Old Jan 2, 2020 | 03:21 PM
  #178
superbird6bbl's Avatar
superbird6bbl
Default Fram oil filters.
Originally Posted by Laramie1997
whats the matter with fram filters? I have been using them for over 50,000 miles and have never had a problem...
I don't know? I have been using them since 1969 on my 440's and I am going to use one on my 99 Dodge 1500 4x4 that I just picked up. I also race a 440 in Sportsman Class.
