new toys coming...
Old Feb 10, 2009 | 07:23 PM
  #21
aim4squirrels's Avatar
aim4squirrels
yeah, I figured if I just called it a stick, y'all would have thought I had gone crazy and swapped in a Manual.
Old Feb 10, 2009 | 07:29 PM
  #22
dodgeram07's Avatar
dodgeram07
Originally Posted by aim4squirrels
go to the Sonnax website, they list their vendors there. Also try this:
http://www.transmissionpartsusa.com/...-sc4647rhe.htm
Just don't buy em out, OK?
thanks.... i still have alot to learn about the transmission before i go ahead and buy a kit.
Old Feb 10, 2009 | 07:34 PM
  #23
CaptCameltoe's Avatar
CaptCameltoe
Some of my goody pile.....Borla headers and exhaust, taylor wires, MP cam and lifters, nascar super truck lookin spoiler
Old Feb 10, 2009 | 08:20 PM
  #24
hometheaterman's Avatar
hometheaterman
I wired my Autometer Transmission temperature gauge up to the headlight switch so that it comes on when I turn my parking lights on. I have my Autometers in the Accord like this too.
I only a have a transmission temperature gauge but the problem I had was getting the wire not to melt. I even ran it in wire loom and it started melting after a short drive. I ran it over the transmission first and that melted. So I tried going across the cross member then up between the transmission and the exhaust to the transmission. This way it doesn't touch anything. However, the heat coming off the exhaust started melting the wire loom after a short drive. I ended up wrapping it in aluminum foil. Not the best looking way if you get under there to check it out but seems to be working great and keeps the wire from melting at least so far and I've been driving it for months. I'm sure you guys will think it's ghetto though.
Old Feb 15, 2009 | 07:04 PM
  #25
aim4squirrels
Toys came in today.
The new A-pillar is in the garage with the first coat of paint drying now. Tomorrow I'll have my exhaust guy drill a new bung hole and weld the wideband bung into the Y-pipe. Wiring should be pretty easy, hopefully. I'm going to tap power off the ciggy lighter as I never use it and it's a pretty heavy fuse (20A IIRC). Not sure if I can wire in a dimmer or not, I'll have to check the wiring.
The grommet in the firewall is TOO easy to get at, LOL! I'll ground the gauges at the spot with the wiper ground on the inside of the firewall up top. I'll take some pics of the install and the finished product.
Old Feb 15, 2009 | 07:20 PM
  #26
BlueBeast2's Avatar
BlueBeast2
Aim I didn't see till now that you replied to my question. Thank You.
Thats kinda dumb though but i guess i'll have to deal with it
